Hide bend line from a flat pattern by iLogic
artemijs.nille
artemijs.nille
Is it possible to hide bend line from a flat pattern by iLogic?
See picture below
Curtis_Waguespack
Hi @artemijs.nille
You can use the Bend Centerline layer to do this.
To do this manually, just go to the Annotate tab > Edit Layers button, and then click the light bulb icon for the BendCenterLine layer to toggle it off.
To do this with an iLogic rule, here is a rule that toggles the layer
oLayer = ThisDrawing.Document.StylesManager.Layers("BendCenterLine")
oLayer.Visible = Not oLayer.Visible
And here is a rule that just turns it off.
ThisDrawing.Document.StylesManager.Layers("BendCenterLine").Visible = False
 I hope this helps.
Curtis
artemijs.nille
Thank you.
Great and easy solution.
