Announcements
Hidden text boxes ruining my drawings please help!!
bmerton
bmerton
Why are text boxes on HIDDEN layers in idw interfering with my dimension lines?  How can I stop this?  See photos
These text boxes contain parameters that refer to the model on that particular page, so I can't use a draft view, or even a different title block as you aren't able to refer to model parameters in these views.
I am trying to use iLogic to suppress/unsuppress these boxes by using layers.  Any other bright ideas would be much appreciated.
VdVeek
Why not place the textboxes outside the drawing border? The textboxes can than even visible.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
If you can reproduce this behaviour without using iLogic or any other programming, then it would be better to ask this question on the Product Forum.
If it is specific to making the textboxes invisible using iLogic then please let us know.
Cheers,
Adam Nagy
Autodesk Platform Services
