- Mute
- Permalink
- Report
I am writing some automation code in iLogic and am having an issue with using IsCoplanarto and IsParallelto
These methods create an error when used with face or face.geometry ie.:
oPlane1.IsParallelTo(oFace.Geometry) or oPlane1.IsCoplanarTo(oFace.Geometry)
The code seems to work fine if i use "On Error Resume Next" or "Try Catch" to handle the error, but i will be needing to debug in the future so i would like to find a way that will not generate an error.
Attached is a file with 2 rules, one with error handling on to show how it should work, the other with error handling off to show the error.
here is my code
'On Error Resume Next Dim oDoc As PartDocument = ThisApplication.ActiveDocument Dim oPlane1 As Plane = Nothing Dim oPlane2 As Plane = Nothing Dim oFaces As Faces = oDoc.ComponentDefinition.SurfaceBodies.Item(1).Faces 'gets too many results but works, using worksurfaces doesnt give me the correct result MessageBox.Show(oFaces.Count.ToString, "Check No. of faces in Surface body") Dim oFace1 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select a face") Dim oFace2 As Face = Nothing oPlane1 = oFace1.Geometry For Each oFace As Face In oFaces If oPlane1.IsCoplanarTo(oFace.Geometry) Then ElseIf oPlane1.IsParallelTo(oFace.Geometry) Then oFace2 = oFace End If Next DistPoints = ThisApplication.MeasureTools.GetMinimumDistance(oFace1, oFace2) Distmm = Round(DistPoints * 10).ToString() + "mm Thick" MessageBox.Show(Distmm, "Title")
