Help: Get iProperties selection Item by API
ngnam1988
ngnam1988
Dears,
Could you please help me check what's wrong in my Code that I'm using to read selection item's iProperties:
Dim AssemblyDOC As AssemblyDocument = _InventorApp.ActiveDocument
Dim ITEM = _InventorApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
	Dim ITEMPropertySets As PropertySets = ITEM.PropertySets
	Dim ITEMPropertySet As PropertySet = nITEMPropertySets.Item("Design Tracking Properties")
	Dim ITEMPartNumber As Property = nITEMPropertySet.Item("Part Number")
	MsgBox("THE PART NUMBER: " & ITEMPartNumber)
End If
I'm using VS2022 + Inventor 2018
Thank you very much!
Replies (10)
WCrihfield
Hi @ngnam1988.  The object you are most likely returning from your Pick method is a ComponentOccurrence, not a Document object.  The ComponentOccurrence object does not directly have a 'PropertySets' property, that is only accessible from a Document type object.  There are a few ways to access the iProperties that are associated with an assembly component, but none of them are direct, the way you have it there.  If going the API way, similar to what you have above, then you will need to get the Document that the assembly component represents first, then you can use that Document to access the iProperties from.  There are two ways to get the Document from a component:
 - ComponentOccurrence.ReferencedDocumentDescriptor.ReferencedDocument
 - ComponentOccurrence.Definition.Document
Or, if the component is a 'top level' one (not within a sub assembly), you may be able to use the iLogic shortcut snippet iProperties.Value(ComponentOccurrence.Name, "PropertySetName", "Property.Name") to access it.
Edit:  Below is an example of one way to alter your code.
	Dim oComp As ComponentOccurrence = ITEM 'or try to Cast it to correct Type
	Dim oCompDoc As Document = oComp.ReferencedDocumentDescriptor.ReferencedDocument
	Dim ITEMPropertySets As PropertySets = oCompDoc.PropertySets
	Dim ITEMPropertySet As PropertySet = ITEMPropertySets.Item("Design Tracking Properties")
	Dim ITEMPartNumber As Inventor.Property = ITEMPropertySet.Item("Part Number")
End If
Wesley Crihfield
(Not an Autodesk Employee)
bradeneuropeArthur
Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
	Dim ITEMPropertySets As PropertySets = ITEM.Definition.Document.PropertySets
	MsgBox("THE PART NUMBER: " & ITEMPartNumber.Value)
End If
Arthur Knoors
Autodesk Affiliations:
ngnam1988
Thanks for your explain @WCrihfield,
It's very useful for me who starting to learn with code.
ngnam1988
Dear @WCrihfield , @bradeneuropeArthur
By this way can we get the physical properties (Mass, Volume, ...) selected item? Could you help me how to do it?
bradeneuropeArthur
	Dim a As Inventor.Document = ITEM.Definition.Document
	MsgBox("THE MASS IS: " & a.ComponentDefinition.MassProperties.Mass)
End If
Arthur Knoors
bradeneuropeArthur
Or more options like this:
	Dim MyMass As String= a.ComponentDefinition.MassProperties.Mass
	Dim MyVolume As String = a.ComponentDefinition.MassProperties.Volume
	Dim MyArea As String = a.ComponentDefinition.MassProperties.Area
	MsgBox("THE MASS: " & MyMass)
	MsgBox("THE VOLUME: " & MyVolume)
	MsgBox("THE AREA: " & MyArea)
End If
Best regards,
Arthur Knoors
Arthur Knoors
ngnam1988
Thank you very much! @bradeneuropeArthur
I learnt to much from your codes. I'm trying get Material of selected item. Could you please help me?
bradeneuropeArthur
Use this:
	Dim ITEMMaterial As Inventor.Property = ITEMPropertySet.Item("Material")
	MsgBox("THE PART NUMBER: " & ITEMMaterial.Value)
End If
Arthur Knoors
Arthur Knoors
ngnam1988
Thanks for your help @WCrihfield @bradeneuropeArthur
I got it, and I can understand the key for my question is:
Dim ITEM As Inventor.Document = ITEM.Definition.Document
bradeneuropeArthur
Please read this overview of properties:
Arthur Knoors
