Help: create a Frame Generator file?
wowrs1608
wowrs1608
I found a few post about editing Frame Generator file. How do I create one with vb.net?
Pete
basautomationservices
There is no API for frame generator. There might be some workaround if you decode the xml attributes in the frame assemblies component definition and the submembers, but this is alot of work and prone to errors since we cannot be sure how the frame generator works under the hood.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
wowrs1608
In an assembly, it is calling FG to create and edit.
Maybe instead using a FEA 1-d element model and add some 2d and 3d connections.
