Having trouble Changing text font size in a drawing sketch
Chris.Truelove
Chris.Truelove
I am having trouble changing the font size within a sketch that is used as part of a border title.
I have tried a number of different ways to do this all of which usually fail with an error relating the the code that is trying to change the font size.
It should be noted that the code works as it should without the extra code that is trying to change the font size.
Below are some snippets of the code that was used to change the font size.
Public Sub Main SketchTextAdd()
' a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Create a new sketch on the active sheet.
Dim oSketch As Inventor.Sketch
oSketch = oDrawDoc.ActiveSheet.Sketches.Add
' Open the sketch for edit so the text boxes can be created.
' This is only required for drawing sketches, not part.
oSketch.Edit
'Identify border type
Dim oBorder = ActiveSheet.Border
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
' Create text with simple string as input. Since this doesn't use
' any text overrides, it will default to the active text style.
Dim sText As String
sText = InputBox("Enter new Title Text", "Secondary Title ", "")
iProperties.Value("Custom", "Second Title "& ActiveSheet.Name) = sText
Dim oTextBox As Inventor.TextBox
Dim oStyle As TextStyle
For Each oTextBox In oTextBoxes
oStyle = oTextBox.Style
oStyle.Font = "Arial"
oStyle.FontSize = 1
Next
If oBorder = "A3" Then
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(22.7, 3.2),oTG.CreatePoint2d(35,2.4), sText)
Else If oBorder = "A4" Then
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(10.39, 3.2),oTG.CreatePoint2d(22,2.4), sText)
Else If oBorder = "A4_P" Then
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(11.15, 6.195), oTG.CreatePoint2d(20.25, 4), sText)
End If
oSketch.ExitEdit
End Sub
and I have also tried the following snippet of code to try and change the font size.
oTextBox.FormattedText = "<StyleOverride Fontsize = '0.5'>" & sText & "</StyleOverride>"
End If
oSketch.ExitEdit
End Sub
I hope someone can help.
Replies (10)
JhoelForshav
@Chris.Truelove
Try this :slightly_smiling_face:
Sub Main' SketchTextAdd()
oSketch.Edit
Dim sText As String
End If
oSketch.ExitEdit
For Each oTextBox In oSketch.TextBoxes
oStyle.FontSize = 1
Next
Chris.Truelove
Thanks for the pointer,
This changed all of the font sizes on all sheets.
I only wanted to change the font size on the A4_P sheet. Sorry I didn't explain that very well.
JhoelForshav
@Chris.Truelove
Like this then? :slightly_smiling_face:
oSketch.Edit
Dim sText As String
Dim oStyle As TextStyle = oTextBox.Style
oStyle.FontSize = 1
End If
oSketch.ExitEdit
End Sub
Chris.Truelove
Thanks again.
Unfortunately that is still changing the font on all sheets!!....
JhoelForshav
Hi @Chris.Truelove
You are right... We are actually changing the actual style that the textbox is using. So every other textbox using this style will be updated aswell... I guess we'll have to create a new style. Try this :slightly_smiling_face:
oSketch.Edit
Dim sText As String
iProperties.Value("Custom", "Second Title " & ActiveSheet.Name) = sText
Dim oStyle As TextStyle = oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.SketchTextStyle
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(22.7, 3.2), oTG.CreatePoint2d(35, 2.4), sText, oStyle)
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(10.39, 3.2), oTG.CreatePoint2d(22, 2.4), sText, oStyle)
Dim A4_P_Style As TextStyle
Try
A4_P_Style = oDrawDoc.StylesManager.TextStyles.Item("A4_P_Style")
Catch
A4_P_Style = oStyle.Copy("A4_P_Style")
A4_P_Style.Font = "Arial"
A4_P_Style.FontSize = 1
End Try
oTextBox = oSketch.TextBoxes.AddByRectangle(oTG.CreatePoint2d(11.15, 6.195), oTG.CreatePoint2d(20.25, 4), sText, A4_P_Style)
End If
oSketch.ExitEdit
End Sub
Chris.Truelove
We are getting there,
The Font type and size for that particular border definition is now entering in a different size and font to the rest of the sheets in the drawing. Unfortunately I cannot control the size of the text or the font used. Editing the lines
Style.Font = "Times New Roman"
Style.FontSize = 1
 Makes no difference to the font size or style. The text is approx. 4 times bigger than the other text that is in the border/Title block.
For reference the font size that is used in the title block is 2.5!!!!.....
Thanks for your help so far.
WCrihfield
Sorry I didn't get back with you sooner on this matter in the last post.  I got caught away at work.
Here's what I was working on yesterday for you.
There are several lines commented out, just to show some optional possibilities.
I was actually thinking specifying the font and its size by specifying the TextStyle you wanted to use, instead of the more difficult route of specifying the individual Font Name, and Font Size, etc.
Then putting a block of code to check the resulting text size compared to the text box size, then offering some options to help correct any issues, in a few different ways like in the following code.
This code I am testing with an A-Size sheet (8.5 in x 11 in), and have a simple rectangle border that is .25 in from all sides of the sheet.  And the rectangle for my text box is being translated to Inches by multiplying by 2.54.
It places the TextBox in the lower left corner of this border (just as an example).
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim oBorder As Inventor.Border = oSheet.Border
Dim oTStyles As TextStylesEnumerator = oDDoc.StylesManager.TextStyles
Dim oTStyle As TextStyle
Dim oTStylesNames As New List(Of String)
For Each oTStyle In oTStyles
	oTStylesNames.Add(oTStyle.Name)
Next
Dim oTStyleName As String = InputListBox("Select a TextStyle for this TextBox.",oTStylesNames," ","Available TextStyles")
oTStyle = oTStyles.Item(oTStyleName)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oPoint1 As Point2d = oBorder.RangeBox.MinPoint
Dim oPoint2 As Point2d = oTG.CreatePoint2d(oPoint1.X + (3*2.54), oPoint1.Y + (.75*2.54))
Dim oSketch As DrawingSketch = oSheet.Sketches.Add
oSketch.Edit
Dim oText As String = InputBox("Enter new Title Text", " ")
'Dim oFText As String = "<StyleOverride Font='Simplex' FontSize='18' Bold-'True' Italic='False' Underline='False'>" & oText & "</StyleOverride>"
'Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddByRectangle(oPoint1, oPoint2, oFText)
Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes.AddByRectangle(oPoint1, oPoint2, oText, oTStyle)
'oTextBox.ShowBoundaries = True
'iLogicVb.DocumentUpdate
'MsgBox("There are " & oTextBox.BoundaryGeometry.Count & " entities within oTextBox.BoundaryGeometry.")
'For Each oSE As SketchEntity In oTextBox.BoundaryGeometry
'	oSE.SketchOnly = False
'	oSE.Construction = False
'	oSketch.GeometricConstraints.AddGround(oSE)
'Next
FitCheck :
If oTextBox.FittedTextWidth > oTextBox.Width Then
	oAns = MsgBox("The text is wider than the text box." & vbCrLf & _
	"Do you want to:  Reduce Font Size [Yes], Edit the contents [No], or Leave it that way [Cancel]?", vbYesNoCancel + vbQuestion, " ")
	If oAns = vbYes Then
		oNewTStyleName = InputListBox("Select a TextStyle for this TextBox.",oTStylesNames," ","Available TextStyles")
		oTextBox.Style = oTStyles.Item(oNewTStyleName )
		'Then GoTo FitCheck (the beginning Of this Size Check Process)
		GoTo FitCheck
	ElseIf oAns = vbNo Then
		oTextBox.Text = InputBox("Edit contents.", " ", oTextBox.Text)
		GoTo FitCheck
	End If  'Don't really need to deal with what happens when they choose Cancel.
End If
oSketch.ExitEdit
Let me know how this works for you.
Wesley Crihfield
(Not an Autodesk Employee)
Chris.Truelove
Thanks for this,
I'm not sure why but when I click Yes if the text does not fit the box. The option to choose another text style pops up as it is supposed to but when that style is selected the code errors. I do like the way that it uses the styles library and I could easily create a coupe of styles with different font sizes. I think it would be better if it just defaulted to one style for all of the borders except the A4_P border and then used a style that was specific to that border.
I also like the catch that allows the user to edit the text again if they want to. Could this be modified to allow the user to edit that same text  if they have already exited this operation. i.e. if a sketch with a text box already exists, can that be edited instead of creating a new sketch and text box.???........
If this is going to take up too much of your time please do not feel obligated to take it further.
Thank you for your help.
WCrihfield
Yes. It can definitely work with an existing DrawingSketch & existing TextBox.
Here's a modified version of my previous code.
(I edited the code in my last post a couple times, right after I posted it to to a misplaced variable name. That may have been what caused the error.)
See if this will work for you.
Sub Main
	Return
End If
Dim oSketch As DrawingSketch = oSheet.Sketches.Item(1) 'you can supply a name, if it has one
oSketch.Edit
Dim oTextBox As TextBox = oSketch.TextBoxes.Item(1) 'you can supply a name, if it has one
FitCheck :
		oTextBox.Style = GetTStyle(oDDoc)
		GoTo FitCheck
		GoTo FitCheck
End If
oSketch.ExitEdit
End Sub
Function GetTStyle(ByRef oDoc As Document) As TextStyle
	Dim oTStyles As TextStylesEnumerator = oDoc.StylesManager.TextStyles
	Next
	Dim oTStyleName As String = InputListBox("Select a TextStyle for this TextBox.", oTStylesNames, " ", "Available TextStyles")
	Return oTStyle
End Function
Wesley Crihfield
Chris.Truelove
That was quick!!!!.......
Unfortunately it errors straight away.
Error Message;
Error in rule: Test 2, in document: Std_Inventor.dwg
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
More Info;
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.DrawingSketches.get_Item(Object Index)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
