Has ilogic solution-derived component.
iva.btblan
iva.btblan
I can't do this control.
Could someone help me?
Only lack of control the dimension of derived.
Control the dimensions in the iam.
Can you share your Rule/Code to accomplish this?
Iva
Replies (12)
dgreatice
Still no idea what do you want. Can more specific?
or do you want make iLogic Form to Control that Model?
you can try to view this first:
https://www.youtube.com/watch?v=q7JOVlJDAuM
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
iva.btblan
I want to control the dimensions by the form.
bradeneuropeArthur
If you know what parameters need to be changed than of course it is possible.
Are you familiar with I-logic and programming in any language?
Arthur Knoors
Autodesk Affiliations:
iva.btblan
A little in Ilogic. I don't know anything in programming.
I'm starting.
bradeneuropeArthur
then what parameters do you need to change?
This is very basic I-logic and programming and should be possible very easily.
But  I do not know exactly what needs to be changed and how the model file is generated.
Please give more info regarding the parameters to be changed and in what value and unit and expression.
Arthur Knoors
iva.btblan
When they open the IAM will realize that the box of the form did not allow the dimensions to be edited.
All the dimensions are in the form's box.
Open the dialog box in the form and try to change.
The dimensions doesn't reflect on the models.
Thank you.
bradeneuropeArthur
Please make some step by step sceenshots.
Arthur Knoors
dgreatice
Did you see my youtube?
iva.btblan
I'm sending the video to better understand the doubt.
Can you download the files I sent?
I found your video on YouTube.
and almost that.
Thank you.
dgreatice
You wrong call that parameter in 03.05.0005.02:1, it must be call to 03.05.0005.02:1
try this,
1. Place Component 03.05.0005.01 to main assembly, place grounded, then make BOM > reference.
2. Check you rule in Rule0, you call that parameter in 03.05.0005.02:1?
3. change all become, example in first line: (Parameter"03.05.0005.01:1", "Comprimento") = Comprimento
iva.btblan
Thank you for your help. Subject solved.
dgreatice
which the answer make it solve? Please close this topic with solve status.
