I had a quick look in the API help and there is little information on the cable and harness API 2020.
You can use either send keys or mouse control to navigate through the dialogue box.
The below opens the "Add files to List" dialogue in Reports in the assembly environment. It will at least remove some tedious clicks and help navigate.
'https://docs.microsoft.com/en-us/dotnet/api/system.windows.forms.sendkeys.send?view=net-5.0
Sub Main
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item("HSL:Cable:Generate_Report")
Call oControlDef.Execute
Call wait(0.6)
System.Windows.Forms.SendKeys.SendWait("{F10}")
System.Windows.Forms.SendKeys.SendWait("{RIGHT 2}")
System.Windows.Forms.SendKeys.SendWait("{ENTER}")
System.Windows.Forms.SendKeys.SendWait(" ")
End Sub
'https://stackoverflow.com/questions/15857893/wait-5-seconds-before-continuing-code-vb-net
'Timer to allow time for form to come into focus.
Private Sub wait(ByVal seconds As Integer)
For i As Integer = 0 To seconds * 100
System.Threading.Thread.Sleep(10)
' ThisApplication.DoEvents()
Next
End Sub
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
