go to back view from front view with ilogic
hi!
I want a ilogic code to turn my part from front view to back view on x axis!
in inventor when i'm on front view and i put oCamera.ViewOrientationType in back view the rotation is on y axis and i dont that!
thanks for your help!
MechMachineMan
1. Change your modelling standards to get the user to redefined the view cube in the parts/assemblies before saving.
or
2. Use the proper API calls to change the rotation. See attached link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-3F0FE1EC-94C4-4590-910C-93DBB85E9C7D
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
i want a API method but i'm not really good in API :disappointed_face:
