Announcements
Getting iLogic rule to save triggerd parts individually
phila
phila
I have an iLogic rule to run on IPT's and some IAM's after the file saves to a STEP FILES folder.
The upper assemblies typically do not have the trigger set to save as a STEP file.
When in the context of an upper assembly, that does not have the trigger, and a save is done, the entire upper assembly is saved to a STEP file with the correct name of the lower level IPT/IAM that has a trigger. Unfortunately the STEP file contains the assembly not the individual part or respective assembly.
It works perfectly in the individual files but if I'm not careful, it overwrite the existing file with the assembly. Not good.
I think my problem, aside not knowing programming, is with the "Stepfilename = Thisdoc.path". Since I am in an upper assembly, it makes sense that would be the Thisdoc.path I'm in and not the individual file that has a trigger.
Stepfilename = ThisDoc.Path & "\STEP FILES\" & ThisDoc.FileName(False)
How do I get the rule to save each file, that has a trigger, to their respective file and path?
Hope this makes sense.
Replies (24)
phila
Makes sense. I think.
At this point I don't know where to add the code or what changes are needed to get it to work. My attempt:
Tried pasting the All Referenced Documents code above the call to StepTranslator and get an error that "All other subs or functions must be after Sub Main()"
Removed the Debug print part.
Changed the line
oSTEPTranslator.SaveCopyAs(ThisApplication.oRefDoc.DisplayName, oContext, oOptions, oData)
Obviously not the way to do it.
How is it implemented?
phila
I have tried to figure this out without success. Did searches on the error trying to understand what it means. All the results so far assume you know VB like the back of your hand to begin with in their explainations. I don't know enough other than to be dangerous about writing code.
Can't get the examples given on the site referenced to work, same Sub Main  error. Seems they have to run within a greater program.
Completly stumped.
Is there a way to get the All Referenced Dociuments code to sequence through and create the STEP files? Of course there is, but how?
phila
Figured out the link examples are VB not ilogic. Seem to be two entirely different worlds. Each sub? may or may not work in VB or VB in ilogic. First line returns a compile error for the text that is to show in the dialog box. Works in iLogic not VB. I'm lost.
Once again, I am asking for help/direction/pay you on how to get this to work?
MechMachineMan
Here's a a few links that has a bit more on Sub Main() / End Sub and AllReferencedDocuments
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
http://au.autodesk.com/au-online/classes-on-demand/search?full-text=Inventor+iLogic&productName=&lan...
>> This one specifically: http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/product-design-suite/ma1936#ch...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
phila
Thanks for the additional links. I will look at them.
I finally got this to work as I wanted.
Added:
oODocName = ThisDoc.Document
and changed the line
oSTEPTranslator.SaveCopyAs(oODocName, oContext, oOptions, oData)
It now saves the correct STEP and fortunately in the correct folders of the different products as well. Got lucky.
Here is the rule as it is now:
' Start of iLogic code *******************************************
'query user
question = MessageBox.Show("Is a STEP file needed for " & ThisDoc.FileName(False), "Sav2STEP",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbNo Then
Exit Sub
oPath=ThisDoc.Path
oFolder = oPath & "\STEP FILES"
oRevNum = iProperties.Value("Project", "Revision Number")
'check to see if in drawing
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
doc = ThisApplication.ActiveDocument
MsgBox("This iLogic rule will only run from a part or assembly", MsgBoxStyle.Exclamation, "Document Type Error")
Exit Sub
Dim Sdate As String = DateString '& " " & TimeString
'Check for the STEP folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'Delete Files from folder containing this file name
Dim path As String = ThisDoc.Path & "\STEP FILES\"
For Each foundFile As String In My.Computer.FileSystem.GetFiles (path,Microsoft.VisualBasic.FileIO.SearchOption.SearchAllSubDirectories,
"*" & ThisDoc.FileName(False) & "*")
My.Computer.FileSystem.DeleteFile(foundFile)
Next
'Start of export code ***********************************************
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument _
, oContext, oOptions) Then
oOptions.Value("ApplicationProtocolType") = 3
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
' Set export name of STEP file
oData.FileName =ThisDoc.Path & "\STEP FILES\" & ThisDoc.FileName(False) & " " & oRevNum & ".stp"
'oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
' End of export code ***********************************************
' Ask user if they want to open the export folder
OpenFolder = MessageBox.Show("Export successful! " & _
"- open containing folder now?", "Sav2STEP", _
MessageBoxButtons.YesNo, _
MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
If OpenFolder = vbYes Then
Process.Start("explorer.exe", ThisDoc.Path & "\STEP FILES\")
Else ' User says continue
'Return
' End of iLogic code **************************************************
