Getting component from Browsernode
NachitoMax
NachitoMax
Hey
I have a method that finds the browsernode from the component by using NativeObject. What is the method of doing it the other way round? i.e. finding the object from the Browsernode? I am trying to turn off the components in the assembly but i only have the browser nodes in my method as i am looping them by folder.
The RepNode.NativeObject is the Browsernode and i need to check if its an assembly. If it is, i need to run all child components visiblity off
Dim RepNodes As BrowserNodesEnumerator = oFolder.BrowserNode.BrowserNodes
                        For Each RepNode As BrowserNode In RepNodes
                            If oFolder.Name = oViewRep.Name Then
                                RepNode.NativeObject.Visible = True
                                If oFolder.Name = "NOZZLE" Then
                                  'LOOP THE TOP LEVEL COMPONENTS
                                   'IF COMPONENT IS ASSEMBLY,
                                   'LOOP CHILD COMPONENTS AND TURN OFF
                                End If
                            End If
                        Next
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
marcin_otręba
heck this:
Dim oPane As BrowserPane
oPane = ThisDoc.Document.BrowserPanes.Item("Model")
On Error Resume Next
    ' Get the last visible child node under the sub-assembly occurrence
    Dim oTargetNode As BrowserFolder
    Dim i As Long
    For i = oPane.TopNode.BrowserFolders.Count To 1 Step -1
                 oTargetNode = oPane.TopNode.BrowserFolders.Item(i)
			 If oTargetNode.Name = "NOZZLE" Then
				Dim onode As BrowserNode
				For Each onode In oTargetNode.BrowserNode.BrowserNodes
					Dim occ As ComponentOccurrence = onode.NativeObject
					MessageBox.Show(occ.name, "Title")
				Next
                         End If
    Next
NachitoMax
Thanks for the reply
i figure it out last night, i needed to make an occurrence and assign the browsernode to it
   Dim oComp As ComponentOccurrence = RepNode.NativeObject
   If oComp.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
      For Each SubComp As ComponentOccurrence In oComp.SubOccurrences
         SubComp.Visible = False
      Next
   End If
End If
Nacho
