Getting all parameters of an holefeature
Hi All,
i am writing a rule wich accsesses the parameters of the holefeatures in my parts.
When i use the code below on a part with a counterbore hole it only returns the parameter of the drilled part and ingnores the
depth and the diameter of the counterbore.
I attached the partfile with the rule.
SyntaxEditor Code Snippet
Dim oDoc as Inventor.PartDocument = ThisDoc.Document
Dim oParam as Inventor.Parameter
Dim oTol as Inventor.Tolerance
Dim i As Integer
Dim oFeat As PartFeature
Dim oDim as FeatureDimension
For i=1 To oDoc.ComponentDefinition.Features.count
    oFeat=oDoc.componentdefinition.Features.item(i)
    If oFeat.Type = 83912192 Then        '83912192 = Holefeatures
        For n=1 To oFeat.FeatureDimensions.count
        oDim=oFeat.FeatureDimensions.item(n)
        oParam = oDim.Parameter
               MessageBox.Show(oFeat.Type & oParam.Name & oParam.Tolerance.HoleTolerance, " ", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
        Next
    End If
Next
Hi Udo.eckardt,
Welcome to the Comumunity!!
I hope the following code will be helpful for your requirement.
Dim oPart As Document
oPart = ThisApplication.ActiveDocument
Dim oHoleFeature As HoleFeature
For Each oHoleFeature In oPart.ComponentDefinition.Features.HoleFeatures
Dim oHoleType As String
If oHoleFeature.HoleType = 21507 Then
oHoleType = "CounterBoreHole"
ElseIf oHoleFeature.HoleType = 21506 Then
oHoleType = "CounterSinkHole"
ElseIf oHoleFeature.HoleType = 21505 Then
oHoleType = "DrilledHole"
ElseIf oHoleFeature.HoleType = 21508 Then
oHoleType = "SpotFaceHole"
End If
MsgBox ("Counter bore Diameter: " & oHoleFeature.CBoreDiameter.Value & vbNewLine & _
        "Counter Bore Depth: " & oHoleFeature.CBoreDepth.Value & vbNewLine & _
        "Hole Type: " & oHoleType & vbNewLine & _
        "Hole Name:" & oHoleFeature.Name & "")
Next
now i got an idea of how to read the parameters and its properties.
This was helpful.
Udo
