Getting accurate RangeBox XYZ values
NachoShaw
Advisor Advisor
Message 1 of 56
NachoShaw
Hey
I'm using the RangeBox method to return the XYZ values of some parts. My problem with this is that if the part was angled, I do not get the correct XYZ but instead, I get XYZ of the angled part as if it was flat. Hard to explain but let's say for example the part was 10" x 10" x 1". that's the RB set of values but if the same part was angled at 45 degrees, I then get something like 10" x 10" x 5"...
is there a method of routine available that would allow me to obtain the true XYX even if the part wasnt laid flat or angled?
thanks
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Accepted solutions (3)
Replies (55)
Message 2 of 56
clutsa
Are you getting the range box of the component or the component definition?
Dim compOcc = Component.InventorComponent("Layout") 'you part name here
Dim RBAssy As Box = compOcc.RangeBox
Dim RBDef As Box = compOcc.Definition.RangeBox
MessageBox.Show("RBAssy X = " & RBAssy.MaxPoint.X - RBAssy.MinPoint.X & " Y = " & RBAssy.MaxPoint.Y - RBAssy.MinPoint.Y & " Z = " & RBAssy.MaxPoint.Z - RBAssy.MinPoint.Z & vbCr _
				& "RBDef X = " & RBDef.MaxPoint.X - RBDef.MinPoint.X & " Y = " & RBDef.MaxPoint.Y - RBDef.MinPoint.Y & " Z = " & RBDef.MaxPoint.Z - RBDef.MinPoint.Z, "Title")
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 56
NachoShaw
Hi
i am getting the size from the ComponentDefinition. In your code, this doesnt appear to be part of the API
i cant find anything related to Component or InventorComponent("") as you describe.
here is my current code that returns X, Y or Z dependent on what values i need
Private Function GetPartSize(oDoc As Document, axis As String) As Double
    Dim i As Long
    Dim rangeBox As Box
    Dim pxMin As Double, pyMin As Double, pzMin As Double
    Dim pxMax As Double, pyMax As Double, pzMax As Double
    Dim PartSizeX As Double, PartSizeY As Double, PartSizeZ As Double
    Dim oCompDef As ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oBox As Box
    Set oBox = oCompDef.rangeBox
    With oBox
    pxMin = .MinPoint.x: pyMin = .MinPoint.y: pzMin = .MinPoint.z
    pxMax = .MaxPoint.x: pyMax = .MaxPoint.y: pzMax = .MaxPoint.z
    End With
    Dim oUOM As UnitsOfMeasure
    Set oUOM = oDoc.UnitsOfMeasure
    PartSizeX = oUOM.ConvertUnits((pxMax - pxMin), kCentimeterLengthUnits, oUOM.LengthUnits)
    PartSizeY = oUOM.ConvertUnits((pyMax - pyMin), kCentimeterLengthUnits, oUOM.LengthUnits)
    PartSizeZ = oUOM.ConvertUnits((pzMax - pzMin), kCentimeterLengthUnits, oUOM.LengthUnits)
    Select Case axis
        Case "X"
        GetPartSize = SizeSort(2)
        Case "Y"
        GetPartSize = SizeSort(1)
        Case "Z"
        GetPartSize = SizeSort(0)
    End Select
    'Set oDoc = Nothing
End Function
but this doesnt return the true XYZ values, it returns the XYS of the rangebox which can be different based on the position / angle of the part
Nacho
Message 4 of 56
clutsa
My code was iLogic. Are you looking to figure out the size of the whole assembly or a part in the assembly?
Message 5 of 56
BrianEkins
This should help explain what you're seeing.
http://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Message 6 of 56
clutsa
Try this... it defaults to using the first occurrence origin to orientate the assembly
    Dim i As Long
    Dim rangeBox As Box
    Dim oOcc As ComponentOccurrence
    Set oOcc = oCompDef.Occurrences.Item(1)
    Dim oTransMatrix As Matrix
    Set oTransMatrix = oOcc.Transformation
    Dim oBox As Box
    Dim NewMax As Point
    Dim NewMin As Point
    Set NewMax = oBox.MaxPoint
    Set NewMin = oBox.MinPoint
    Call NewMax.TransformBy(oTransMatrix)
    Call NewMin.TransformBy(oTransMatrix)
    pxMin = NewMin.x: pyMin = NewMin.y: pzMin = NewMin.Z
    pxMax = NewMax.x: pyMax = NewMax.y: pzMax = NewMax.Z
    Debug.Print (PartSizeX & " " & PartSizeY & " " & PartSizeZ)
    Select Case axis
        Case "X"
        GetPartSize = PartSizeX
        Case "Y"
        GetPartSize = PartSizeY
        Case "Z"
        GetPartSize = PartSizeZ
    End Select
    'Set oDoc = Nothing
End Function
Edit: never-mind this post. I was thinking on my drive home and realized that I'm only turning the box that is already the wrong size. This isn't going to work at all Smiley Frustrated
Message 7 of 56
NachoShaw
Hey Clutsa
i am only really interested in getting the part sizes for a cut list
Nacho
Message 8 of 56
NachoShaw
Hey Brian
i had already found this post thanks and tried the coding which sort of results the same as my current method. In the post its mentioned that a user input to select the orientation could work so, i wondered if it would be worth exploring a method to loop through the edges and select the longest to make that selection? Obviously it would still have its pitfalls with some shapes but as we mainly work with flat panels, it certainly would suffice
thoughts?
Nacho
Nacho
Message 9 of 56
Curtis_Waguespack
@NachoShaw wrote:
...exploring a method to loop through the edges and select the longest to make that selection...
Hi @NachoShaw,
Here is a quick iLogic snippet to select the longest edge of a body. I'm not sure how you were thinking of using it once identified/selected though.  Do you have more info?
I hope this helps.
Curtis
' Get the active document. This assumes it is a part document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oBodies As ObjectCollection
oBodies = ThisApplication.TransientObjects.CreateObjectCollection
oBody = oCompDef.SurfaceBodies(1)
'add body to collection
oBodies.Add (oBody)
Dim oEdges as Edges
oEdges = oBody.Edges
oMaxLength = 0
Dim oMaxEdge As Edge
For Each oEdge In oEdges
    oLength = ThisApplication.MeasureTools.GetMinimumDistance(oEdge.StartVertex, oEdge.StopVertex)
 	If oLength > oMaxLength Then
		oMaxEdge = oEdge
		oMaxLength = oLength
	End If
Next
'select the edge
oPartDoc.SelectSet.Select(oMaxEdge)
Message 10 of 56
Curtis_Waguespack
Hi @NachoShaw
I messed around with this a bit and came up with this example.
Note that I ran it on a simple assembly file that was created from a Multibody base model using the Make Components tool to populate the assembly.
It looks at each occurrence in the assembly and does this:
  • places another occurrence of that component
  • finds the longest edge
  • then uses the 2 faces that share the longest edge to mate to the assembly work planes
  • then it creates a new part file
  • and then invisibly copies the solid body from the mated occurrence into the new file in the mated oreintation
  • then it gets the range box, XYZ values
  • then it determines Length, Width, and Thickness, with length being largest, thickness being the smallest
  • then it creates or edits a custom iproperty in the original part file called Size
  • then it cleans up the extra, mated occurrence, and dumps the temporary part file
Then it opens the BOM editor (I didn't see a way to add the custom iprop to BOM view, so that needs to be done manually (unless I missed something).
Note that I didn't test it much, so it might trip over sheet metal files, sub assemblies, Virtual Components, etc.... but it's something to start with.
I hope this helps.
Curtis
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Set a reference to the transient geometry object.
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	'insert new occurence
	Dim oOcc1 As ComponentOccurrence
	oOcc1 = oAsmCompDef.Occurrences.Add( _
        oOccurrence.Definition.Document.FullFileName, oMatrix)
	'rename occurence incase error causes it to
	'be left behind
	oOcc1.Name = "iLogic_Temporary_Component_Remove_As_Needed |" & oOcc1.Name
	'get the longest edge on the component
	Dim oMaxEdge As EdgeProxy
	oOcc1.Grounded = False
	oMaxLength = 0
	For Each oEdge In oOcc1.SurfaceBodies(1).Edges
		oLengthValue = ThisApplication.MeasureTools.GetMinimumDistance( _
		If oLengthValue > oMaxLength Then
			oMaxEdge = oEdge
			oMaxLength = oLengthValue
		End If
	Next
	'get the 2 faces that include the longest edge
	oFaces = oMaxEdge.Faces
	'create a face proxy for the first face
	Dim oAsmFace1 As FaceProxy
	Dim oFace1 As FaceProxy
	oFace1 = oFaces.Item(1)
    Call oOcc1.CreateGeometryProxy(oFace1, oAsmFace1)
	'create a face proxy for the second face
	Dim oAsmFace2 As FaceProxy
	Dim oFace2 As FaceProxy
	oFace2 = oFaces.Item(2)
    Call oOcc1.CreateGeometryProxy(oFace2, oAsmFace2)
	'create work plane proxies
	Dim oAsmPlane1 As WorkPlane
	Dim oAsmPlane2 As WorkPlane
 	oAsmPlane1 = oAsmCompDef.WorkPlanes.Item(1) 'Assembly YZ Plane
 	oAsmPlane2 = oAsmCompDef.WorkPlanes.Item(2) 'Assembly XZ Plane
	'constrain the occurence to the assembly origin workplanes
	oConstraint1 = oAsmCompDef.Constraints.AddMateConstraint(oAsmFace1, oAsmPlane1, 0)
	oConstraint2 = oAsmCompDef.Constraints.AddMateConstraint(oAsmFace2, oAsmPlane2, 0)
	' Create a new part, invisibly.
    Dim oTempDoc As PartDocument
    oTempDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), False)
	'get the first solid body in the occurence document
    Dim oBody As SurfaceBody
    oBody = oOcc1.Definition.Document.ComponentDefinition.SurfaceBodies.Item(1)
	oMatrix = oOcc1.Transformation
	'copy the solid from the assembly occurence to the temporary file
	'in the constrained orientation
	Call oTempDoc.ComponentDefinition.Features.NonParametricBaseFeatures.Add(oBody, oMatrix)
	'get the range box
	oBox = oTempDoc.ComponentDefinition.SurfaceBodies.Item(1).RangeBox
	'Get active document unit of measure
	oUOM = oOccurrence.Definition.Document.UnitsOfMeasure
	'Converts length unit to a string
	Dim oUnits As String = oUOM.GetStringFromType(oUOM.LengthUnits)
	'converts the units string
	If oUnits = "centimeter" Then
		oUnits = " cm"
	Else If oUnits = "millimeter" Then
		oUnits = " mm"
	Else If oUnits = "inch" Then
		oUnits = Chr(34)
	Else If oUnits = "foot" Then
		oUnits = " ft"
	Else If oUnits = "meter" Then
		oUnits = " m"
	End If
	'get the range box's max point
	Dim oMax As point
	oMax = oBox.MaxPoint
	'get the range box's min point
	Dim oMin As point
	oMin = oBox.MinPoint
	'convert the value from Inventor's internal cm
	'To the Umits Of Measure Of the orginal component file
	X = oUOM.ConvertUnits ((oMax.X - oMin.X), "cm", oUOM.LengthUnits)
	Y = oUOM.ConvertUnits ((oMax.Y - oMin.Y), "cm", oUOM.LengthUnits)
	Z = oUOM.ConvertUnits ((oMax.Z - oMin.Z), "cm", oUOM.LengthUnits)
	'figure out which is length, width and thickness
	Dim oLength As Double = MaxOfMany (X,Y,Z) & " "
	Dim oWidth As Double = X + Y + Z - MaxOfMany (X,Y,Z) - MinOfMany(X,Y,Z) & " "
	Dim oThick As Double = MinOfMany (X,Y,Z) & " "
	'round values
	Dim oDecimals As Integer = 3
	oLength = Round(oLength,oDecimals)
	oWidth  = Round(oWidth,oDecimals)
	oThick  = Round(oThick,oDecimals)
	'create string value
	oSize = oThick & oUnits & " x " &  oWidth & oUnits & " x " & oLength & oUnits
	'set custom iproperty in the component file
	iProperties.Value(oOccurrence.Name,"Custom", "Size") = oSize
	'delete the temporariily constrained occurence
	oOcc1.Delete
	'close the temporary new part file
	oTempDoc.Close
Next 'occurence
'Open BOM editor dialog box
Dim oCtrlDef As ControlDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd")
oCtrlDef.Execute
Message 11 of 56
kmiller
So I would like to add a little "swing" so to speak in this.  We thought we could get piece size information from a drawing view by measuring the view width and height and doing some conversions with the scale.  This is how we where getting by with having to deal with the rotation, axis, etc.. because our parts are rarely put on a drawing in the same direction they are modeled.  This works well for some, however when you start putting full rounds, fillets, etc.. and radial type work the view dimension isn't technically accurate to what you would have as a result of placing a dimension on the drawing for say the length of the piece.  Anyone have any suggestions and pointers to get this information without having to go through all the hoops of setting up custom planes/rotations, etc..  We run through 100's of custom parts a day and so are just trying to come up with a way to automate the dimensional display of the L, H, Thickness of a piece on our production tickets.
If this response answers your question please click "Accept as Solution".
Message 12 of 56
DRoam
Coming here from this idea thread where @kmiller and I were talking about how this could be done.
One possible solution I threw out there was this: for any non-aligned parts, create a UCS that's aligned with the part's orientation, then have an iLogic rule in the part which would fire whenever its geometry changes, which does some Move Body commands to get the part aligned with the WCS, then captures the extents, then reverts the part back to its normal orientation.
Attached is a dataset (in Inventor 2017 format) that demonstrates just that. Now, this is extremely messy... the code, that is (although the models are messy, too Smiley Tongue). It works, but as nothing more than a proof of concept. If you tried using the code on a different Derived part, it may run without errors, but it would probably rotate the part in all the wrong directions and spit out the wrong dimensions. However, I think someone more skilled with the mathematics of coordinate system transformations than I am could get it to be fully robust.
To test it out, open up "Unaligned Derived Part" and run the rule in it. It should spit out some measurements for the extents. They should correspond to the dimensions of the part, to a pretty high degree of accuracy.
Then, open "Multibody Master", change the dimensions of the part, then go back to the Unaligned Derived Part and hit update. It should spit out the correct new dimensions of the part.
If you want to see better what it's doing, open up the code and un-comment the MessageBox near the end. Then you'll be able to see the series of Move Body transformations it's used to get the part aligned with the WCS.
Not sure how useful this is, even if it can be made fully robust, because you still have to manually create a UCS for each un-aligned part...
@kmiller, is that a deal-breaker for you? Or is this worth investigating further?
Message 13 of 56
marcin_otręba
i have one simple (but not entirely correct) solution for that issue.. change all your model into sheetmetal and uncheck thickness from rule. Then you can use flat pattern extens + z dimmension. Flat pattern is always oriented along longest edge.
Of course uou will get big disadvantage because it will complicate recognision if part is sheet metal part, but you can accomplish it using check if thickness is from rule and if it match to z dimmension of flat pattern, or you can give some additional marking or check parent template.
One of companies i work do it this way and they are satisfied from this approach.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 14 of 56
kmiller
The UCS may be the way we need to go.  Sorry I was out at Autodesk University this past week.  If you haven't ever gone, I recommend that you do.  🙂  I am going to review what you have going on an posted for proof of concept.  I also have another resource I can ask in terms of a solution which spiked this whole discussion for us in the first place.
I will also review the post about the sheet metal thickness.  But I don't think that is going to help us at all.  Worth a look at though.
Thanks everyone for your suggestions in this and all other posts.  I will be sure to let you know what we ended up doing.
Message 15 of 56
DRoam
Very exciting news -- this was implemented in Inventor 2020.3! It was added very quietly for some reason -- I haven't seen an announcement or release note regarding it anywhere. But it works perfectly!
It should be available in 2020.3 and all later versions (2021+). The method to use is SurfaceBody.OrientedMinimumRangeBox. Here's a usage example:
' Get the current Part document.
Dim partDoc As PartDocument = ThisDoc.Document
' Get surface body to measure (assume it's the first body).
Dim body1 As SurfaceBody = partDoc.ComponentDefinition.SurfaceBodies.Item(1)
' Get the oriented mininum range box of the body.
' NOTE: "OrientedMinimumRangeBox" was added in Inventor 2020.3/2021.
Dim minBox As OrientedBox = body1.OrientedMinimumRangeBox
' Get length of each side of mininum range box.
Dim dir1 As Double = minBox.DirectionOne.Length
Dim dir2 As Double = minBox.DirectionTwo.Length
Dim dir3 As Double = minBox.DirectionThree.Length
' Convert lengths to document's length units.
Dim uom As UnitsOfMeasure = partDoc.UnitsOfMeasure
dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits)
dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits)
dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits)
' Sort lengths from smallest to largest.
Dim lengths As New List(Of Double) From {dir1, dir2, dir3 }
lengths.Sort
Dim minLength As Double = lengths(0)
Dim midLength As Double = lengths(1)
Dim maxLength As Double = lengths(2)
' Display minimum rangebox size.
MessageBox.Show("Oriented Minimum Rangebox Size: " &
	minLength.ToString("#.###") & " x " & midLength.ToString("#.###") & " x " & maxLength.ToString("#.###"),
	"Oriented Minimum Rangebox", MessageBoxButtons.OK, MessageBoxIcon.Information)
This works perfectly for getting the actual size of parts that were modeled skewed relative to the origin, either by accident or due to for skeletal modeling workflows.
Many thanks to Autodesk for getting this implemented! And feel free to brag a bit more about things like this 😉
Message 16 of 56
jtylerbc
That's great news.  Whenever we finally get around to upgrading (still stuck on 2018 for various reasons), this will be a nice bonus.  At my company, we have an illogic-based system for our part descriptions that works very well for parts that are parallel to the origin planes, but once you go to a part that is modelled askew, it forces you into various workarounds.
The most common is to use Move Body or Direct Edit features to reorient the part, which causes our existing rule to work properly again.  However, this is an extra step.  In addition to that extra work, the part (which is usually the result of multibody workflows) must then be manually constrained, adding even more extra work.
The skewed parts are a small enough minority of what we do that it isn't a major problem.  But it is enough of a nuisance that I'll be glad to see a real solution to it.
Message 17 of 56
bradeneuropeArthur
Any idea how to use this for assemblies too?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 18 of 56
kmiller
WOW - Thanks for posting.  I can't wait to check it out.
We also are stuck on 2019 as a department (due to things i can't control) but have access to 2020 and 2021 software.  I don't think I would have ever found it.  If anything thanks for the knowledge.
Message 19 of 56
_dscholtes_
When I was looking for a macro to retrieve part dimensions (in 2018), I found an already started discussion about this here (from 2007). The math (vector and matrix) code behind the auto-orientation works like a charm. I had only to fix some issues in the code regarding design assumptions and evaluation conditions. It's a good start point in developing your own macro.
For retrieving the dimensions of an assembly, I re-used most of the code for parts. But I let the user select two pieces of geometry as reference to align the assembly correctly. It takes a user less time to select those references than the macro does analyzing all of the bodies in a large assembly.
Curtis_W in reply to: NachoUK <u+200e>10-18-2018 05:23 PM
•places another occurrence of that component
•finds the longest edge
•then uses the 2 faces that share the longest edge to mate to the assembly work planes
@Curtis_Waguespack nbsp;_W
  • What happens if the longest edge is not an outside (perimeter) edge, but part of a hole?
  • What happens when the 2 faces are not perpendicular to each other, as in a plate with bevels?
  • What happens when there's no longest edge, as in a circular plate?
And one that caused some confusion amongst and opposition from our draftsmen and work preparation dept.:
  • Do you mind the longest edge being the diagonal side of a right-angled triangle?
    (opposition prefers to have it oriented and dimensioned along the longest of the two non-diagonal edges)
@DRoam
Thanks for posting this new feature. As I understand your code, this is unusable for looping through bodies in multi-body parts because it results per body only (and does not take spacing between bodies into account). Still may come in handy in particular situations.
Message 20 of 56
Is there anything like this for folded sheet metal parts?  I tried DRoam's bit of code and it works except not with sheet metal parts even in the flat pattern.
