getting a quotation mark to show in part description through iLogic
Very new to iLogic here this is pretty much my first real dabble into it. Im try to create a part template for tube sections that will auto populate part number and descriptions, i can get it to work but the only thing i cant make work is the quotation mark after the tube size in the description, for example i want it to show     1" Tube 304      but every time i put the quotation mark in it makes the rule crash. the best i can get is   1 Tube 304     example of my rule below
If OD = 25.4 mm And WT = 1.6 mm  And GRADE = 304 Then iProperties.Value("Project", "Description") = "1 Tube 304"
If OD = 50.8 mm And WT = 1.6 mm  And GRADE = 304 Then iProperties.Value("Project", "Description") = "2 Tube 304"
Any ideas on how to fix?
Joe
Sergio.D.Suárez
Hi, try to load the character inside the chain through the numeric code. Try to execute the following code.
If OD = 25.4 mm And WT = 1.6 mm  And GRADE = 304 Then iProperties.Value("Project", "Description") = "1" & Chr(34) & " Tube 304"
If OD = 50.8 mm And WT = 1.6 mm  And GRADE = 304 Then iProperties.Value("Project", "Description") = "2" & Chr(34) & " Tube 304"
 I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks mate, it worked perfectly.
Where does that numeric code come from is it just the character map unicode?
