Get Tolerances From HoleThreadNote (Not from Part)
c_hoppen
c_hoppen
The question is similar to
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/get-tolerance-for-holethreadnote/td-...
but the tolerances are to be read from the drawing (added manually):
I've already dug through the object tree in VBA, but haven't found anything yet.
Christoph
Zach.Stauffer
Can you use the HoleThreadNote tolerance, as shown in the API?
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-9F0BDB8C-4AB4-4180-A121-8E198287DB2D
c_hoppen
Zach, this is not the tolerance I_m looking for.
HoleThreadNote.Tolance is "empty":
Maybe it's not exposed to the API?
Best,
Christoph
Zach.Stauffer
Very interesting. No matter how I try to set the tolerance, it won't read using iLogic (or VBA I assume). Weird for them to have an API function that has what appears to be invalid return data.
