Get Tolerance for HoleThreadNote
Hillebrand
Hillebrand
I need some help.
I want to collect all tolerances used in a drawing view.
Collecting the drawing tolerances for DrawingDimensions works fine. But it is a problem to get the tolerances defined for  holefeatures in parts model.
   HoleThreadNote first = sheet.DrawingNotes.HoleThreadNotes.Cast<HoleThreadNote> ().First ();
   string a = first.Text.Text;
   // a = "n3,00 H7 DURCH"
   string holTol = first.Tolerance.HoleTolerance;
   // holTol = "";
   string shaftTol = first.Tolerance.ShaftTolerance;
   // shaftTol = "";
Is there another method to get the "model" tolerances? Only possible by parsing the text string?
Thank you!
Regards
Petra
HideoYamada
This code get Tolerance object that is corresponding to HoleThreadNote.
Sub test()
    Dim oSheet As Sheet
    Set oSheet = ThisApplication.ActiveDocument.ActiveSheet
    Dim oHoleThreadNote As HoleThreadNote
    Set oHoleThreadNote = oSheet.DrawingNotes.HoleThreadNotes(1)
    Dim oFace As Face
    For Each oFace In oHoleThreadNote.Intent.Geometry.ModelGeometry.Faces
        If TypeOf oFace.CreatedByFeature Is HoleFeature Then
            Dim oHoleFeature As HoleFeature
            Set oHoleFeature = oFace.CreatedByFeature
            Dim oTolerance As Tolerance
            Set oTolerance = oHoleFeature.HoleDiameter.Tolerance
            Debug.Print oTolerance.HoleTolerance
            Exit For
        End If
    Next oFace
End Sub
oHoleThreadNote.Intent.Geometry.ModelGeometry is pointing the edge in the part model.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Hillebrand
Works perfect!
Thank you so much!
