Get Information of Solid Bodies from treeview using API
Hi everyone,
Is it possible get the information of Solid Bodies(2):
1. Solid1:  (Boss- Extrude1)
2. Solid2: (Boss- Extrude2)
from tree view  marked in red in below image using API?
Please suggest me .
Regards
frederic.vandenplas
This code shows the displayed name of the solid (vba)
Public Sub GetSolidInformation()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As ComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oSurfBody As SurfaceBody
    For Each oSurfBody In oDef.SurfaceBodies
        MsgBox (oSurfBody.Name)
    Next oSurfBody
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
