Get DisplayName of a parent's part
Is there a way to get all the Display Name of a Parent's Part or Assembly using a VBA "Inventor 2019".
i tried to extract the compenent but i don't know how to get the parents :
Private Sub CommandButton1_Click()
    Dim OApp As Inventor.Application
    Set OApp = GetObject(, "Inventor.Application")
    Dim oDoc As Document
    Set oDoc = OApp.ActiveDocument
    Dim oAllrefdocs As DocumentsEnumerator
    Set oAllrefdocs = oDoc.ReferencedFiles
    Dim oSubDoc As Document
    Dim oSubDoc1 As Document
    Dim sMsg As String
    Dim iLeafNodes As Long
    Dim iSubAssemblies As Long
    Dim i As Integer
For i = 1 To oAllrefdocs.Count
    ListBox1.AddItem oAllrefdocs.Item(i).DisplayName
Next
End Sub
i get the parent name of level N+1
Sub test()
Set oDoc = ThisApplication.ActiveDocument
Dim Parent As Document
Set Parent = oDoc.ReferencingDocuments.Item(1)
MsgBox (Parent.DisplayName)
End Sub
But i would like to get all the displayname's parents of all levels
thank you in advance.
Sub test()
End Sub
Sergio.D.Suárez
Hi, Here is an example of how to get the father of each occurrence within an assembly.
I have not tried it, but I think it should work.
Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    For Each oOcc As ComponentOccurrence In Occurrences
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
		Try
			Dim oParentocc As ComponentOccurrence
			oParentocc = oOcc.ParentOccurrence
			oParent = oParentocc.DisplayName
		Catch
			oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName)
		End Try
		oData = oParent & "@" & oOcc.Name & "@" & "Level - " & Level
			MessageBox.Show(oData)
	Next
End Sub
 Tell me a little about what you want to achieve to see if I can help you
regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
