Get Dimenions or Form Control Feature item number with iLogic
johnster100
johnster100
I am creating a drawing which will have values updated with iLogic.
I am having trouble updating Feature Control Frames and Dimensions. I am looking for a method to obtain their item numbers so I can control their location and values.
I can get the objects using the select set method but I do not know how to obtain the item number of the object once I have it.
code for getting object with select set:
Dim oFeatContFrame As FeatureControlFrame
For Each oFeatContFrame In ThisDoc.Document.SelectSet
	'adds a note to the control frame
	oFeatContFrame.notes = "111"
Next
but as said above I do not know how to get the item number so I can later set the value:
ActiveSheet.Sheet.FeatureControlFrames.item(x).notes = "111"
thanks,
John
Replies (0)
