Get Component in subassembly without iteration
Inside my assembly I have a subassembly called "MySubAssembly", which contains a component called "MyComponent".
I want to get a reference to MyComponent WITHOUT iterating through all components in MySubAssembly and trying to match names.
I'm sure that there is a function along the lines of CreatePathToComponent("MySubAssembly", "MyComponent") (the syntax is obviously incorrect) and that I have even used it at some point, but I'm unable to find it in my code or anything about it online.
Thanks in advance
bradeneuropeArthur
Try this:
I have not tested it yet!
Public Sub Main
	Dim ass As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
	Dim Occurrences As Inventor.ComponentOccurrences = ass.ComponentDefinition.Occurrences
'Dim occ As ComponentOccurrence
Dim assocc As Inventor.AssemblyDocument = ass.ComponentDefinition.Occurrences.ItemByName("MySubAssembly").Definition.Document
Dim PartOcc As Inventor.ComponentOccurrence = assocc.ComponentDefinition.Occurrences.ItemByName("MyComponent")
Dim p As Inventor.PartDocument =PartOcc.Definition.Document
End Sub
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
WCrihfield
@Anonymous
FYI
The function you were trying to remember is called "MakePath()".
There is a built-in iLogic Snippet for using it listed under the System tab / Components (classic).
Here is the online help reference page that talks about it:  (you'll need to scroll to the bottom of the web page)
Component Functions Reference (iLogic)
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfieldYes, this is it, thanks!
I started doubting if I really remembered it existing. :grinning_face_with_big_eyes:
