Get and insert drawing sheet number in part list
1830108CDDDF
1830108CDDDF
Hello everyone.
I need to add the sheet number where the object (assembly/subassemby) is located. The sheet number is added in a column into part list in the drawing. Like this
The columns name's is
|  ITEM |   QTY   |   DESCRIPTION   |   PART NUMBER    |   GO TO  |
So the sheet number is headed to 'GO TO' column.
For example, I have an assembly named 'A_1'
Within there are subassemblies named:
  • 'SA_1.1'
  • 'SA_1.2'
Let's suppose that assembly 'A_1' is in sheet number 1 and the subassmblies are in the consecutive sheet (2 and 3).
So when a make the drawing for assembly 'A_1' the parts list should be like this:
    'SA_1.1'           1                      -                               -                          2
    'SA_1.2'           1                      -                               -                          3
I'm new with iLogic, but my reasoning is the next one to achieve what I'm looking:
  • Read/get the sheet number of the active sheet. I found a way to achieve this with the folowing thread: Reference Drawing Sheet Number with iLogic
  • Open the (object) in the active sheet, insert the number into iProperties Keywords section (<-Where the part list shows the sheet number). I haven't found a way to make this, that's why I'm looking for help.
Thanks in advance, and regards from México.
dalton98
Heres a simmilar post Link
use the example provied by krieg
1830108CDDDF
Thanks!, It worked
