General Note - Change Color
a81383
a81383
I'm trying to change the color of my newly created note in the following code. But it will not change,. I've tried numerous separate approaches and it really seems like the code should work but the black text remains.
	Dim oDwgDoc As Document = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDwgDoc.Sheets.Item(1)
	Dim oGeneralNotes As GeneralNotes = oSheet.DrawingNotes.GeneralNotes
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	oFontSize1 = 1 * 2.54 '2.54 coverts to inches
	oText1 = "OBSOLETE"
	Dim oBorder As Border = oSheet.Border
	Dim oTitleBlock As TitleBlock = oSheet.TitleBlock
	Dim oPlacementPoint1 As Point2d
		xrev2 = oBorder.RangeBox.MinPoint.X + 3
		yrev2 = oBorder.RangeBox.MaxPoint.Y - 1
		oPlacementPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(xrev2, yrev2)
	Dim sFormattedText As String = "<StyleOverride FontSize ='" & oFontSize1 & "'>" & oText1 & "</StyleOverride>"
	oGeneralNote = oGeneralNotes.AddFitted(oPlacementPoint1, sFormattedText)
	oGeneralNote.Rotation = -0.785398
	Dim red As Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Red
	oGeneralNote.Color = red
WCrihfield
Hi @a81383.  I think that you may simply be missing one minor step in your process.  After you create the new Color object, try setting its property named 'ColorSourceType', which has a ColorSourceTypeEnum type value, to the 'kOverrideColorSource' variation of that Enum.  Then set that Color as the value of the Color property of the GeneralNote
Below is a quickie iLogic rule example I just made to test changing the color of a GeneralNote using its Color property, and it worked just fine for me.  But I am using Inventor 2024 version, and not sure which version you may be using, or if it makes any difference.  There are also other ways to change its color, but this is the most direct way.
Dim oDN As DrawingNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingNoteFilter, "Pick Drawing General Note.")
If oDN Is Nothing OrElse (TypeOf oDN Is Inventor.GeneralNote = False) Then Return
Dim oGN As Inventor.GeneralNote = oDN
Dim oRed As Inventor.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0, 1)
oRed.ColorSourceType = ColorSourceTypeEnum.kOverrideColorSource
oGN.Color = oRed
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Another way to change the color of a drawing annotation is to change which 'Style' it is using.  When you do this, you do not want to do it like oObject.Style.Color = oMyColor...instead either have a Style already prepared, or create a new Style, then set that other Style as the value of oObject.Style.  Doing it with oObject.Style.Color will change the Style itself, not just that one object, and changing the Style itself may effect all other annotations in the drawing that are also using that same Style.  In this case, we are talking about a GeneralNote, and it has a property named 'TextStyle' which has a TextStyle object as its value.
Below is an example of doing it that way.
Dim oSheet As Inventor.Sheet = oGN.Parent
Dim oDDoc As DrawingDocument = oSheet.Parent
Dim oOrigStyle As Inventor.TextStyle = oGN.TextStyle
Dim oOtherStyle As Inventor.TextStyle = Nothing
Try
	oOtherStyle = oDDoc.StylesManager.TextStyles.Item("BlueTextStyle")
Catch
	oOtherStyle = oOrigStyle.Copy("BlueTextStyle")
End Try
oOtherStyle.Color = ThisApplication.TransientObjects.CreateColor(0, 0, 255, 1) 'Blue
oGN.TextStyle = oOtherStyle
oSheet.Update
Wesley Crihfield
a81383
@WCrihfield, thank you very much for your responses. I set my oGeneralNote variable " As GeneralNotes" before creating the note itself. So, I would have never thought of setting it as an Inventor.GeneralNote before changing colors, but that's what did it. Out of curiosity I'll take a look at the changing the style as well.
Dim oGN As Inventor.GeneralNote = oGeneralNote
Thank you again!
