Forms/ iLogic
PumaBH
Forms/ iLogic
PumaBH
Hello All,
Looking for a little bit of help with a standard model:
it consists of 8 corner pieces and a number of box section parts that change in length given the overall unit size.
Width = 2100mm
Height = 1600mm
length = 800mm
Hinge Door Opening = 400mm
fixed access panel = 250mm
These dimensions will generally change upon application. But the construction will always be the same. with the 50mm box section and corners.
I'm looking for help regarding specific forms/iLogic/Rules that i can use to generate different size assemblies where i can modify the specs creating various assemblies quickly.
Kind Regards,
Ben
Replies (9)
kacper.suchomski
Look this video:
https://youtu.be/aPph2AYHxN4
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
A.Acheson
Can you give a little more info as to how you have currently constructed the model? Is it currently an assembly? Can you share a very simple file set of the .ipt and .iam that make up the assembly? Ensure to use pack and go and you can attach as a zip compressed folder.  Use squares and circles or remove confidential detail if your actually assembly is not shareable as is. Without knowing your current approach there is multiple routes that can be taken.
Depending on how you approach this you can use as little ilogic or as much as you want. Is there any skeletal model controlling the frame size?
There is a dedicated forum for ilogic questions here but this might be a good place for now where you can get advice on modelling techniques from the experts with or without ilogic.
Regards
Alan
PumaBH
Hi Alan,
yes, as shown below. the frame is constructed using a 3D sketch and frame generator.
the box section profiles are not standard and i have added these via the author feature and used frame generator to assemble them. the corner pieces are added to my content center and assemble via iMates flush outside faces with the box section. The 2 of center posts are also frame generator. offset from the 3D sketch.
in terms of iLogic, i would like to set this up to be modified quickly in terms of the 3 main outside dimensions @ 2100mm, 1600mm, and 800mm. Further to this the previous image i sent has panels assembled. i assume i'd be able to use iLogic so that when the main outside dimensions change the panel sizes change accordingly.
Kind Regards,
Ben
A.Acheson
Hi Ben,
Thanks for the additional info a little easier to see what you have. Can you replace the key dimensions with user parameters? If so you can then either drive them directly through the form or indirectly if parameters are in a different part such as your sheetmetal parts or master sketch part. You should be able to find the parameters in the ilogic editor then add and drive all the measurements if you want to group by model type etc.
Regards
Alan
PumaBH
So i've revisited this recently with spare time.
i have set up a configuration form based on the user parameters which drives the 3D sketch overall size dimensions.
and have a set parameter rule when i want to run the changes applied in the form.
the code for the set parameter rule is here:
Public Sub Main()
	CopyUserParams()
End Sub
Private Sub CopyUserParams()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
    End If
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
        ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
            ' Add the assembly parameters to the part.
            For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
                ' Check to see if the parameter already exists.
                Dim checkParam As UserParameter = Nothing
                Try
                    checkParam = refDocUserParams.Item(asmUserParam.Name)
                Catch ex As Exception
                    checkParam = Nothing
                End Try
                If checkParam Is Nothing Then
                    ' Create the missing parameter.
                    refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
                Else
                    ' Update the value of the existing parameter.
                    checkParam.Expression = asmUserParam.Expression
                End If
            Next
        End If
    Next
	iLogicVb.UpdateWhenDone = True
End Sub
However, this all works well prior to the frame generator feature being used. the form does exactly what i require.
after i have used frame generator the form does not work and displays an error. I'm assuming it's because the frame generated parts are the issue as the form works with these parts suppressed.
is there a iLogic rule i can use to update the frame members once or during the set parameters rule is run?
The assembly is attached in a .zip file which contains the frame generated members in a file and the 3D sketch.
Kind Regards,
Ben
PumaBH
i forgot to mention: i can suppress the frame generated parts and run the form/rules to change the overall size and then un-suppress the frame generated parts and rebuild the model for the members to change to the correct length.
PumaBH
A.Acheson
You will likely need a update snippet for the assembly and possibly a rebuild all. If you carry out the task without code can you write down the exact sequence of events you do? This includes entering into documents, hitting update and or rebuild all.
See help file for assembly update and Assembly Rebuild
You will find the same for the PartDocument. Changing the parameters of the sketch will likely need a part update to happen.
Regards
Alan
PumaBH
Without code i'd simply edit the 3D sketch part and update the overall dimensions. return back to the assembly. and use the rebuild all button in the manage tab. the frame generated assembly would then rebuild and suit the 3D sketch modifications.
in theory i'd like to use the form for dimension changes to the 3D sketch then when i use the set parameters button on the form it updates the sketch and rebuilds the frame generated parts to suit the 3D sketch dimensions.
i know i need:
ThisDoc.Document.Rebuild()
and maybe i need this code?
If Suppress="Yes" Then
Component.IsActive("Part_name")=True
ElseIf Suppress="No" Then
Component.IsActive("Part_name")=False End If
but i can't work out how to implement it in the set parameters code i have shared before
