- Mute
- Permalink
- Report
I need to format the Thickness, Width, and Length parameters on a group of parts from the assembly level.
I know this has been done, and I found what I though were many solutions, none of which worked. At least I was able to screw it up. I'm finally at a point it looks like the rule is running, but nothing is changing.
I need to verify the rule is running only on parts that are modifiable. I'd also like the rule to run if is executed in a part file.
I've attached my latest failure.
Dewayne
Inventor Pro 2023
Vault Pro 2023
Inventor Pro 2023
Vault Pro 2023
