Format Parts List Table Columns
gerrardhickson
gerrardhickson
Hi All,
Is there a way to format parts list table columns, similar to how you right click and select "format column" to set the parameters for unit formatting etc?
Cheers
bradeneuropeArthur
This is for what I know not API supported!
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
A.Acheson
Hi @gerrardhickson
Looking at the API help I see only limited access to the custom column formatting.
2024 API help here.
Regards
Alan
gerrardhickson
That's what I was afraid of. I had a look at the API too, but I hoped there was some other detail I missed.
