- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Morning,
We use part templates for some commonly used parts. When opened these templates open a form where you can edit specific parameters of the part.
Eg. When the nameplate template is opened, a form opened and you are able to edit the information on the nameplate.
Currently the model will update after every change made within the form, which takes a long time since the info text is embossed for drawing visibility.
Is it possible to configure the form to update the model only once the Done button is pressed?
