For loop for repeated operation
ArunS2DHBM
Message 1 of 9
ArunS2DHBM
I have an i-logic rule to be executed for 20 different parts.
Select Case N01_Dia
''N01_Dia=10.3
Case 10.3
If  N01_Sch = "sch-5" Then
	N01_Thk = 1.24
Else If  N01_Sch = "sch-10" Then
	N01_Thk = 1.24
Else If  N01_Sch = "sch-20" Then
	N01_Thk = 1.24
Else If  N01_Sch = "sch-30" Then
	N01_Thk = 1.24
Else If  N01_Sch = "sch-40" Then
	N01_Thk = 1.73
''N01_Dia=13.7
Case 13.7
N01_Thk = 1.65
N01_Thk = 1.65
N01_Thk = 1.65
N01_Thk = 1.65
N01_Thk = 2.24
End if
End Select
The above same conditions needs to apply for Part name N02, N03, N04... up to N20.
if write individually the rule size will be big,
i will be selecting parameter number of pipe <=20 depending on my requirement, to which the rule should run for that many number of pipe
Please help me with a for-loop condition
Replies (8)
Message 2 of 9
J.Pelfrene
Dim sch_list As List(Of String) = New List(Of String)({N01_sch, N02_sch, N03_sch})
Dim thk_list As List(Of Double) = New List(Of Double)({N01_thk, N02_thk, N03_thk})
Dim dia_list As List(Of Double) = New List(Of Double)({N01_dia, N02_dia, N03_dia})
For i As integer = 0 To sch_list.Count
    Select Case dia_list.Item(i)
    'N01_Dia=10.3
    Case 10.3
        If  sch_list.Item(i) = "sch-40" Then
            thk_list.Item(i) = 1.73
        Else
            thk_list.Item(i) = 1.24
    'N01_Dia=13.7
    Case 13.7
            thk_list.Item(i) = 2.24
        Else
            thk_list.Item(i) = 1.65
   End Select
Next
Something like this could work?
There may be different ways to define and initialize a List, IEnumerable or ObjectCollection. Depends a bit on what kind of objects these are / come from.
Message 3 of 9
ArunS2DHBM
Thanks for the reply,
I'm getting the below error when I run the code
Error in rule: Rule0, in document: Mainassembly_Assembly.iam
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Can you please help me with that, I'm using inventor 2020 version
also, I have total of 20 pipes, I don't want to run the rule for all the 20 pipes, I will be having a parameter "Num_of Pipe" based on that number say 5, then the rule should run for the first 5 pipes in the list.
Message 4 of 9
fullevent
Hallo @ArunS2DHBM,
this could do it..
Dim temp As String, temp_sch As String, temp_thk As String, j As String
For i = 1 To 20
	j = Format(i, "00")
	temp = "N" & j & "_Dia"
	temp_sch = "N" & j & "_sch"
	temp_thk = "N" & j & "_thk"
	Select Case temp
		''N01_Dia=10.3
		Case 10.3
		If  temp_sch = "sch-5" Then
			temp_thk = 1.24
		Else If  temp_sch = "sch-10" Then
			temp_thk = 1.24
		Else If  temp_sch = "sch-20" Then
			temp_thk = 1.24
		Else If  temp_sch = "sch-30" Then
			temp_thk = 1.24
		Else If  temp_sch = "sch-40" Then
			temp_thk = 1.73
		''N01_Dia=13.7
		 Case 13.7
		 temp_thk = 1.65
		temp_thk = 1.65
		temp_thk = 1.65
		 temp_thk = 1.65
		 temp_thk = 2.24
	End Select
Next
I hope it helps you.
Enjoy
Edit: I was to slow ^^
Aleksandar Krstic
Produkt- und Projektmanager
Message 5 of 9
ArunS2DHBM
j = Format(i, "00")
having issue in this line
Error on Line 5 : Too many arguments to 'Public ReadOnly Default Property Chars(index As Integer) As Char'.
Message 6 of 9
fullevent
I can't understand this error..
I tried now this short iLogic
i = 5
j = Format(i, "00")
MsgBox(j)
..and it works for me..
I'm sorry, but i don't know what could be wrong with that simple line.. 😕
Aleksandar Krstic
Message 7 of 9
ArunS2DHBM
Hi @fullevent
That error is rectified, but the program doesn't take the value to the parameter. i.e my N01_thk is not updating.
Message 8 of 9
ArunS2DHBM
The rule is running, but the value is not updating, I think the reason is  Sch_list.Item(i) takes its value, instead of the parameter name.
i.e Sch_list.Item(i) Should be N01_Sch, instead, it takes Sch_list.Item(i) as Sch-5,
is any way to update this...
Thanks in advance.
Message 9 of 9
fullevent
Hi @ArunS2DHBM,
you mean N01_thk in your code is an user-parameter?
Didn't know that, but then you can do something like this
For i = 1 To 20
	j = Format(i, "00")
	Select Case temp
		''N01_Dia=10.3
		Case 10.3
		If  Parameter("temp_sch") = "sch-5" Then
			Parameter("temp_thk") = 1.24
		Else If  Parameter("temp_sch") = "sch-10" Then
		Else If  Parameter("temp_sch") = "sch-20" Then
		Else If  Parameter("temp_sch") = "sch-30" Then
		Else If  Parameter("temp_sch") = "sch-40" Then
			Parameter("temp_thk") = 1.73
		''N01_Dia=13.7
		 Case 13.7
			Parameter("temp_thk") = 1.65
			Parameter("temp_thk") = 2.24
	End Select
Next
Best regards,
Aleksandar Krstic
