FolderBrowserDialog() not working with vb.net
mindaV3J2J
mindaV3J2J
I get that this function is undefined, although it should enable me to pick the folder I need. Here's the code I'm using to do so.
Private Function BrowseForFolder(prompt As String) As String
Using dialog As New FolderBrowserDialog()
dialog.Description = prompt
If dialog.ShowDialog() = DialogResult.OK Then
Return dialog.SelectedPath
Return String.Empty
End Using
End Function
How can I fix this?
WCrihfield
Hi @mindaV3J2J.  It may simply be due to the lack of an Imports statement in your rule's header for the System.Windows.Forms resource, because it may not recognize the object types.  This slightly edited version of your code works just fine for me in a regular iLogic rule without any Imports statements.
Sub Main
	Dim sFolder As String = BrowseForFolder("Pick A Folder")
	MsgBox("sFolder = " & sFolder,,"")
End Sub
	Using dialog As New System.Windows.Forms.FolderBrowserDialog()
		If dialog.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
		Return String.Empty
	End Using
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
mindaV3J2J
that's not working for me unfortunately. Am I missing a reference maybe? I added the one that allowed me to use the inventor API, but no luck with this.
mindaV3J2J
Additionally, it cannot find the System.Windows.Forms library. How can I get around this?
mindaV3J2J
heres my code as well.
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Runtime.InteropServices.ComTypes
Imports System.Windows.Forms
Imports Inventor
Namespace d
Module Module1
Sub Main()
Dim invApp As Inventor.Application = GetInventorInstance()
If invApp Is Nothing Then
' MessageBox.Show("Autodesk Inventor is not running.")
Return
Dim oDoc As Document = invApp.ActiveDocument
Dim folderPath As String = BrowseForFolder("Please select an input folder")
If String.IsNullOrEmpty(folderPath) Then
Return
Dim oFSO As Object = CreateObject("Scripting.FileSystemObject")
Dim oFolder As Object = oFSO.GetFolder(folderPath)
Dim setFilePath As String = BrowseForFolder("Please select an output folder")
If String.IsNullOrEmpty(setFilePath) Then
Return
For Each oFile As Object In oFolder.Files
If LCase(oFSO.GetExtensionName(oFile.Name)) = "iam" Then
Dim sFilename As String = folderPath & "\" & oFile.Name
Dim oAsmDoc As AssemblyDocument = invApp.Documents.Open(sFilename, False)
' MessageBox.Show(oAsmDoc.FullFileName)
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
For Each oRefDoc As Document In oRefDocs
If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oSheetMetDoc As PartDocument = invApp.Documents.Open(oRefDoc.FullFileName, True)
Dim oCompDef As SheetMetalComponentDefinition = oSheetMetDoc.ComponentDefinition
Dim oDef As FlatPattern = oCompDef.FlatPattern
If oDef Is Nothing Then GoTo NextOcc
Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2018" &
"&OuterProfileLayer=IV_INTERIOR_PROFILES" &
"&InvisibleLayers=IV_TANGENT;IV_ROLL_TANGENT"
Dim prevName As String = oSheetMetDoc.DisplayName
Dim arr() As String = prevName.Split("."c)
prevName = arr(0)
Dim sFname As String = setFilePath & "\" & prevName & ".dxf"
Dim oDataIO As DataIO = oCompDef.DataIO
oDataIO.WriteDataToFile(sOut, sFname)
oCompDef.FlatPattern.ExitEdit()
NextOcc:
Next
If oDoc IsNot oAsmDoc Then
oAsmDoc.Close(True) ' True = skip save
Next
' MessageBox.Show("Flat patterns exported to " & setFilePath)
End Sub
Private Function GetInventorInstance() As Inventor.Application
Try
Return DirectCast(Marshal.GetActiveObject("Inventor.Application"), Inventor.Application)
Catch ex As Exception
Return Nothing
End Try
End Function
Return String.Empty
End Using
End Function
End Module
End Namespace
