Flipping a flat pattern in sheet metal part
When I enter a drawing made from a sheet metal part, inventor always defaults the flat pattern to have all the bends going down.  I actually need the bends coming in as 'up' instead. Is there any way to automate this ?
Replies (10)
bradeneuropeArthur
You know that you can change that in the flat-pattern definition within inventor!?
Or do you need it with coding?
And do you need it in i-logic; VBA; Vb.net; or else?
Regards
Arthur Knoors
Autodesk Affiliations:
Yes, I do it manually every time as of now. Trying to automate processes for my company.  Preferably ilogic.  Will try to incorporate this with a code that streamlines most of the process of making drawings.
bradeneuropeArthur
Dim a As Inventor.PartDocument = ThisDoc.Document
'Dim su As Inventor.DocumentTypeEnum = a.DocumentSubType
If a.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	Dim s As Inventor.SheetMetalComponentDefinition = a.ComponentDefinition
	Dim f As Inventor.FlatPattern = s.FlatPattern
	'f.FlatPatternOrientations.ActiveFlatPatternOrientation.FlipAlignmentAxis
	Dim fl As Inventor.FlatPatternOrientation = f.FlatPatternOrientations.Item(1)
	fl.FlipBaseFace= True
	'MsgBox ("")
	End If
Arthur Knoors
bradeneuropeArthur
Or use this to flip it back an forward:
	If fl.FlipBaseFace = False Then
		fl.FlipBaseFace = True
		ElseIf fl.FlipBaseFace = True
			fl.FlipBaseFace= False
		End If
	End If
Arthur Knoors
Looks great, would you happen to know if this rule can be run from a drawing ?  It is usually in the drawing where my coworkers notice that the part needs to be flipped. (The majority of the bends need to be up instead of down).
bradeneuropeArthur
sure it can hang on..
Arthur Knoors
bradeneuropeArthur
Dim dwg As Inventor.DrawingDocument = ThisDrawing.Document
Dim v As Inventor.DrawingView = dwg.ActiveSheet.DrawingViews.Item(1)
'v.ReferencedDocumentDescriptor.ReferencedDocument
Dim a As Inventor.PartDocument = v.ReferencedDocumentDescriptor.ReferencedDocument 'ThisDoc.Document
		End If
dwg.Update
	End If
Arthur Knoors
bradeneuropeArthur
More user friendly with a Picker selection from the user:
Dim v As Inventor.DrawingView '= dwg.ActiveSheet.DrawingViews.Item(1)
v = ThisApplication.CommandManager.Pick(Inventor.selectionfilterenum.kDrawingViewFilter,"Select a Flat Pattern View")
		End If
dwg.Update
	End If
Arthur Knoors
bradeneuropeArthur
Next the error will occur when the View is no Flat Pattern view:
Now you receive a message if it is not:
v = ThisApplication.CommandManager.Pick(Inventor.selectionfilterenum.kDrawingViewFilter, "Select a Flat Pattern View")
If v.IsFlatPatternView = True Then
		End If
dwg.Update
	End If
Else
	MsgBox("This View Contains no Flat Pattern")
	End If
Arthur Knoors
Thanks, code will be used !
