Flat pattern dxf export layer config
florescu.d95
florescu.d95
Over time, by reading the forums and combining and modifying several ideas, I have created the following rule that exports the sheet metal flat pattern as a DXF and it works for assemblies and single parts.
I would like to add more customization options to it such as being able to choose which layers get exported, layer colour, line type without having to edit the code every time.
The way I would do it is by using a global form, problem is that I have no idea how to do it.
Sub Main()
        If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Assy
		If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Part
		End Sub
        Sub Assy()
         Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
         Dim oAsmName = oAsmDoc.DisplayName.Replace(".iam", "")
        Dim RUsure = MessageBox.Show(
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo)
	 	If RUsure = vbNo Then
            Return
        End If
        Dim oPath = ThisDoc.Path
        Dim oFolder = oPath & "\" & oAsmName & " DXF Files"
        If Not System.IO.Directory.Exists(oFolder) Then
            System.IO.Directory.CreateDirectory(oFolder)
        End If
        Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
        For Each oRefDoc As Document In oRefDocs
            If (oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then
                Continue For
            End If
            If (oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
                Continue For
            End If
            If (oRefDoc.Dirty = True) Then
                Continue For
            End If
            Dim oDrawDoc As PartDocument = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
            Dim oFileName = oRefDoc.DisplayName.Replace(".ipt", "")
            Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition
            Try
                Dim customPropertiesSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties")
                Dim customName As String = "XXX"
                Try
                    customName = customPropertiesSet.Item("PF_PRT_ZNR").Value
                Catch
                End Try
                Dim designTrackingPropertiesSet = oRefDoc.PropertySets.Item("Design Tracking Properties")
                Dim description As String = designTrackingPropertiesSet.Item("Description").Value
                Dim StockNumber As String = designTrackingPropertiesSet.Item("Stock Number").Value
				Dim PartNumber As String = oFileName
                Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name
                Dim newFileName As String =
                    oFolder & "\" & PartNumber & " " & Material & ".dxf"
                If oCompDef.HasFlatPattern = False Then
                    oCompDef.Unfold()
                Else
                    oCompDef.FlatPattern.Edit()
                End If
                Dim sOutA As String
                sOutA = "FLAT PATTERN DXF?AcadVersion=2000" & _
        "&OuterProfileLayer=IV_OUTER_PROFILE&OuterProfileLayerLineType=37633&OuterProfileLayerLineWeight=0,0500&OuterProfileLayerColor=0;0;0" & _
        "&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InteriorProfilesLayerLineType=37633&InteriorProfilesLayerLineWeight=0,0500&InteriorProfilesLayerColor=0;0;0" & _
		"&BendUpLayer=IV_BEND&BendUpLayerLineType=37633&BendUpLayerColor=143;175;143" & _
		"&BendDownLayer=IV_BEND_DOWN&BendDownLayerLineType=37634&BendDownLayerColor=143;175;143" & _
		"&FeatureProfilesUpLayer=IV_FEATURE_PROFILES&FeatureProfilesUpLayerLineType=37633&FeatureProfilesUpLayerColor=0;0;255" & _
		"&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerLineType=37634&FeatureProfilesDownLayerColor=0;0;255" & _
		"&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=0;0;255" & _
		"&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=0;0;255" & _
		"&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
					Dim sOutB As String
                sOutB = "FLAT PATTERN DXF?AcadVersion=2000" & _
		"&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=175;175;143" & _
		"&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=175;175;143" & _
		"&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL;IV_BEND;IV_BEND_DOWN;"
	Dim ExpSettingQuestion = MessageBox.Show("Do you want to export Bend Lines?", "DXF Export Settings", MessageBoxButtons.YesNo)
If ExpSettingQuestion = vbNo Then oCompDef.DataIO.WriteDataToFile(sOutB, newFileName)
If ExpSettingQuestion = vbYes Then oCompDef.DataIO.WriteDataToFile(sOutA, newFileName)
                oCompDef.FlatPattern.ExitEdit()
            Catch
            End Try
            oDrawDoc.Close()
        Next
	End Sub
	Sub Part()
        Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
             Dim oPartName = oPartDoc.DisplayName.Replace(".ipt", "")
"This will create a DXF file for the current part." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF file?" _
            Return
        End If
        Dim oFolder = oPath
        Dim oRefDoc= oPartDoc
            If (oPartDoc .SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
				i = MessageBox.Show("Part is not a sheet metal part", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
				Return
			End If
			If (oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
			End If
            If (oPartDoc .Dirty = True) Then
            End If
            Try
                Try
                Catch
                End Try
                    oCompDef.Unfold()
                Else
                End If
                Dim sOutA As String
					Dim sOutB As String
            Catch
            End Try
            oDrawDoc.Close()
	End Sub
 Any help is greatly appreciated.
Michael.Navara
Many years ago I made standalone application for creating the config string for DWG/DXF export of flat pattern. It contains all possible options. It was based on this help article
But it was a lot of code and I used WinForms PropertyGrid control to edit the values (not available in iLogic).
I don't know, if it is possible to do the similar (complex) solution using iLogic forms.
You need to implement your own object which describes the options and config string builder which converts that object to string form that you can use later in your code.
florescu.d95
Hi @Michael.Navara ,
I have seen that standalone application here  but could never find it.
Maybe after expand my coding skills i will be able to do something similar.
