Flat pattern dxf export layer config
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Over time, by reading the forums and combining and modifying several ideas, I have created the following rule that exports the sheet metal flat pattern as a DXF and it works for assemblies and single parts.
I would like to add more customization options to it such as being able to choose which layers get exported, layer colour, line type without having to edit the code every time.
The way I would do it is by using a global form, problem is that I have no idea how to do it.
Sub Main() If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Assy If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Part End Sub Sub Assy() Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oAsmName = oAsmDoc.DisplayName.Replace(".iam", "") Dim RUsure = MessageBox.Show( "This will create a DXF file for all of the asembly components that are sheet metal." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo) If RUsure = vbNo Then Return End If Dim oPath = ThisDoc.Path Dim oFolder = oPath & "\" & oAsmName & " DXF Files" If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments For Each oRefDoc As Document In oRefDocs If (oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Continue For End If If (oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For End If If (oRefDoc.Dirty = True) Then Continue For End If Dim oDrawDoc As PartDocument = ThisApplication.Documents.Open(oRefDoc.FullFileName, True) Dim oFileName = oRefDoc.DisplayName.Replace(".ipt", "") Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition Try Dim customPropertiesSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties") Dim customName As String = "XXX" Try customName = customPropertiesSet.Item("PF_PRT_ZNR").Value Catch End Try Dim designTrackingPropertiesSet = oRefDoc.PropertySets.Item("Design Tracking Properties") Dim description As String = designTrackingPropertiesSet.Item("Description").Value Dim StockNumber As String = designTrackingPropertiesSet.Item("Stock Number").Value Dim PartNumber As String = oFileName Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name Dim newFileName As String = oFolder & "\" & PartNumber & " " & Material & ".dxf" If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOutA As String sOutA = "FLAT PATTERN DXF?AcadVersion=2000" & _ "&OuterProfileLayer=IV_OUTER_PROFILE&OuterProfileLayerLineType=37633&OuterProfileLayerLineWeight=0,0500&OuterProfileLayerColor=0;0;0" & _ "&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InteriorProfilesLayerLineType=37633&InteriorProfilesLayerLineWeight=0,0500&InteriorProfilesLayerColor=0;0;0" & _ "&BendUpLayer=IV_BEND&BendUpLayerLineType=37633&BendUpLayerColor=143;175;143" & _ "&BendDownLayer=IV_BEND_DOWN&BendDownLayerLineType=37634&BendDownLayerColor=143;175;143" & _ "&FeatureProfilesUpLayer=IV_FEATURE_PROFILES&FeatureProfilesUpLayerLineType=37633&FeatureProfilesUpLayerColor=0;0;255" & _ "&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerLineType=37634&FeatureProfilesDownLayerColor=0;0;255" & _ "&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=0;0;255" & _ "&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=0;0;255" & _ "&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL" Dim sOutB As String sOutB = "FLAT PATTERN DXF?AcadVersion=2000" & _ "&OuterProfileLayer=IV_OUTER_PROFILE&OuterProfileLayerLineType=37633&OuterProfileLayerLineWeight=0,0500&OuterProfileLayerColor=0;0;0" & _ "&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InteriorProfilesLayerLineType=37633&InteriorProfilesLayerLineWeight=0,0500&InteriorProfilesLayerColor=0;0;0" & _ "&FeatureProfilesUpLayer=IV_FEATURE_PROFILES&FeatureProfilesUpLayerLineType=37633&FeatureProfilesUpLayerColor=0;0;255" & _ "&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerLineType=37634&FeatureProfilesDownLayerColor=0;0;255" & _ "&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=175;175;143" & _ "&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=175;175;143" & _ "&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL;IV_BEND;IV_BEND_DOWN;" Dim ExpSettingQuestion = MessageBox.Show("Do you want to export Bend Lines?", "DXF Export Settings", MessageBoxButtons.YesNo) If ExpSettingQuestion = vbNo Then oCompDef.DataIO.WriteDataToFile(sOutB, newFileName) If ExpSettingQuestion = vbYes Then oCompDef.DataIO.WriteDataToFile(sOutA, newFileName) oCompDef.FlatPattern.ExitEdit() Catch End Try oDrawDoc.Close() Next End Sub Sub Part() Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument Dim oPartName = oPartDoc.DisplayName.Replace(".ipt", "") Dim RUsure = MessageBox.Show( "This will create a DXF file for the current part." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF file?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo) If RUsure = vbNo Then Return End If Dim oPath = ThisDoc.Path Dim oFolder = oPath Dim oRefDoc= oPartDoc If (oPartDoc .SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then i = MessageBox.Show("Part is not a sheet metal part", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) Return End If If (oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then End If If (oPartDoc .Dirty = True) Then End If Dim oDrawDoc As PartDocument = ThisApplication.Documents.Open(oRefDoc.FullFileName, True) Dim oFileName = oRefDoc.DisplayName.Replace(".ipt", "") Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition Try Dim customPropertiesSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties") Dim customName As String = "XXX" Try customName = customPropertiesSet.Item("PF_PRT_ZNR").Value Catch End Try Dim designTrackingPropertiesSet = oRefDoc.PropertySets.Item("Design Tracking Properties") Dim description As String = designTrackingPropertiesSet.Item("Description").Value Dim StockNumber As String = designTrackingPropertiesSet.Item("Stock Number").Value Dim PartNumber As String = oFileName Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name Dim newFileName As String = oFolder & "\" & PartNumber & " " & Material & ".dxf" If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOutA As String sOutA = "FLAT PATTERN DXF?AcadVersion=2000" & _ "&OuterProfileLayer=IV_OUTER_PROFILE&OuterProfileLayerLineType=37633&OuterProfileLayerLineWeight=0,0500&OuterProfileLayerColor=0;0;0" & _ "&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InteriorProfilesLayerLineType=37633&InteriorProfilesLayerLineWeight=0,0500&InteriorProfilesLayerColor=0;0;0" & _ "&BendUpLayer=IV_BEND&BendUpLayerLineType=37633&BendUpLayerColor=143;175;143" & _ "&BendDownLayer=IV_BEND_DOWN&BendDownLayerLineType=37634&BendDownLayerColor=143;175;143" & _ "&FeatureProfilesUpLayer=IV_FEATURE_PROFILES&FeatureProfilesUpLayerLineType=37633&FeatureProfilesUpLayerColor=0;0;255" & _ "&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerLineType=37634&FeatureProfilesDownLayerColor=0;0;255" & _ "&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=0;0;255" & _ "&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=0;0;255" & _ "&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL" Dim sOutB As String sOutB = "FLAT PATTERN DXF?AcadVersion=2000" & _ "&OuterProfileLayer=IV_OUTER_PROFILE&OuterProfileLayerLineType=37633&OuterProfileLayerLineWeight=0,0500&OuterProfileLayerColor=0;0;0" & _ "&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InteriorProfilesLayerLineType=37633&InteriorProfilesLayerLineWeight=0,0500&InteriorProfilesLayerColor=0;0;0" & _ "&FeatureProfilesUpLayer=IV_FEATURE_PROFILES&FeatureProfilesUpLayerLineType=37633&FeatureProfilesUpLayerColor=0;0;255" & _ "&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN&FeatureProfilesDownLayerLineType=37634&FeatureProfilesDownLayerColor=0;0;255" & _ "&AltRepFrontLayer=IV_ALTREP_FRONT&AltRepFrontLayerLineType=37633&AltRepFrontLayerColor=175;175;143" & _ "&AltRepBackLayerr=IV_ALTREP_BACK&AltRepBackLayerLineType=37634&AltRepBackLayerColor=175;175;143" & _ "&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL;IV_BEND;IV_BEND_DOWN;" Dim ExpSettingQuestion = MessageBox.Show("Do you want to export Bend Lines?", "DXF Export Settings", MessageBoxButtons.YesNo) If ExpSettingQuestion = vbNo Then oCompDef.DataIO.WriteDataToFile(sOutB, newFileName) If ExpSettingQuestion = vbYes Then oCompDef.DataIO.WriteDataToFile(sOutA, newFileName) oCompDef.FlatPattern.ExitEdit() Catch End Try oDrawDoc.Close() End Sub
Any help is greatly appreciated.
