Message 1 of 18
Getting stuck on this one. i have a rule to fire in a sheet metal part that will add parameters and up date them with flat extents, this works fine but i need it to fire from assembly and catch each sheetmetal part in assembly. if parameters exist then it updates them if it dont exist then it adds them and updates them.
this is the simple rule:
Sub Main ' Check if the active document is a part document Dim curDoc = ThisApplication.ActiveDocument If curDoc.DocumentType = kPartDocumentObject Then Else ' Display an error message if the document is not a part document ' MessageBox.Show("This document is not a Sheet Metal Document and can not be run in this document ", "Ope Sorry!") Exit Sub End If ' Get the active document Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument ' Get the component definition of the document Dim oDef As PartComponentDefinition oDef = oDoc.ComponentDefinition ' Check if the document subtype indicates it's a sheet metal document If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Else ' Display an error message if the document is not a sheet metal document ' MessageBox.Show("This document is not a Sheet Metal Document and can not be run in this document ", "Ope Sorry!") Exit Sub End If ' Get the parameters of the component definition Dim oparams As Parameters Dim oparam As Parameter oparams = oDoc.ComponentDefinition.Parameters ' Check if the parameters for flat extents length and width already exist Dim ExtentsLengthExists As Boolean = False Dim ExtentsWidthExists As Boolean = False For Each oparam In oparams If oparam.Name = "DIMA" Then ExtentsLengthExists = True If oparam.Name = "DIMB" Then ExtentsWidthExists = True Next oparam ' Update or add the parameters for flat extents length and width If ExtentsLengthExists Then oparams.Item("DIMA").Value = SheetMetal.FlatExtentsLength * 2.54 Else oparams.UserParameters.AddByValue("DIMA", SheetMetal.FlatExtentsLength * 2.54, "in") End If If ExtentsWidthExists Then oparams.Item("DIMB").Value = SheetMetal.FlatExtentsWidth * 2.54 Else oparams.UserParameters.AddByValue("DIMB", SheetMetal.FlatExtentsWidth * 2.54, "in") End If ' Set the parameters to be exposed as properties oparams.Item("DIMA").ExposedAsProperty = True oparams.Item("DIMB").ExposedAsProperty = True ' Format the custom properties Dim oParameter As Parameter For Each oParameter In oDoc.ComponentDefinition.Parameters.UserParameters Try Dim oFormat As CustomPropertyFormat oFormat = oParameter.CustomPropertyFormat oFormat.ShowUnitsString = False oFormat.ShowLeadingZeros = False oFormat.ShowTrailingZeros = False oFormat.Precision = kThreeDecimalPlacesPrecision Catch End Try Next oParameter ' Check if the project description is empty and prompt user to enter a description ' Dim description As String ' If iProperties.Value("Project", "Description") = "" Then ' description = InputBox("There is no description entered. Please enter one now. This message box will only appear if the Description field in iProperties is empty.", "Enter Description", "Description") ' iProperties.Value("Project", "Description") = description ' End If ' Update the document oDoc.Update ' Set iLogic to update when done iLogicVb.UpdateWhenDone = True End Sub
