Announcements
Finding direction of a kCircleCurve
johnPGNFG
johnPGNFG
What I thought would be a straight-forward task has me banging my head against the desk.
I'm looking to extract curve data off a part and recreate it in another program.  To start, I'm working with a flat piece of plate with no holes or inner edge loops.  I find the top face and then look at each edge and get the data I need for each one.  For straight edges all I need are the end points.  For an arc, I need the end points, center of arc, and the direction (Clockwise or Counterclockwise).
I'm using     foreach(Edge edge in topface.edges)      to cycle through each edge
The problem is sometimes inventor checks the edges going clockwise around the part and other times it will go counterclockwise.  This is a problem when it comes around to an arc (circle curve) edge
I tried the following but I'm not sure what "params" I'm supposed to be using here.  I searched through the API help but couldn't find any info:
Circle circle = arcEdge.Curve[CurveTypeEnum.kCircleCurve];
circle.Evaluator.GetCurvature(ref Double[] Params, ref Double[] Directions, ref Double[] Curvatures);
Should "GetCurvature" fill in the "Directions" and "Curvatures" arrays if I input the Params?  What is "Params" in this case supposed to be?  I've tried filling it in with points along the curve in hopes it would spit out the direction but no luck.  Maybe this isn't the approach I'm supposed to take but it would still be nice to know how to use "GetCurvature".  Any suggestions on how to find direction would be appreciated.
Zach.Stauffer
It appears that if you create empty objects and pass them to the function that it will fill those objects with data. The API is super unhelpful about what the doubles in the different arrays mean though. I'd try it and look at it in a debugger to see what I was getting.
If you look at the "True length of sweep feature" API sample that is how they are using similar functions.
yan.gauthier
From an Arc2D Object, I get the SweepAngle property. if it's greater than 0, then the direction is counterclockwise
johnPGNFG
Is it possible to make an edge an Arc2d object?  I can't seem to make that work.  I can make it an Arc3d object by    Arc3d arc = edge.Geometry;   but  arc.SweepAngle   always returns a positive value.
yan.gauthier
oh, you are in 3d environment.
I think you could maybe make it work by getting the axisVector. In my experience, Inventor seems to be following the opposite to the right hand rule... ? (make a thumbs up with your right hand. your thumb represent the axis direction, your fingers will then point to the rotational direction). But, at least it consistent.
I think your sweep angle will always be either CW or CCW around the axis vector.
use this function :
Arc3d.GetArcData( Center() As Double, AxisVector() As Double, RefVector() As Double, Radius As Double, StartAngle As Double, SweepAngle As Double )
for reference, here's the API example using this function to recreate a wire body of a selected part
Public Sub TaperFace()
    Dim testFace As Face
    Set testFace = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, "Select a planar face")
    ' Get the transient B-Rep and geometry objects.
    Dim tBRep As TransientBRep
    Set tBRep = ThisApplication.TransientBRep
    Dim tg As TransientGeometry
    Set tg = ThisApplication.TransientGeometry
    ' Create the top-level objects needed to construct a wire.
    Dim bodyDef As SurfaceBodyDefinition
    Set bodyDef = tBRep.CreateSurfaceBodyDefinition
    Dim lumpDef As LumpDefinition
    Set lumpDef = bodyDef.LumpDefinitions.Add
    Dim shellDef As FaceShellDefinition
    Set shellDef = lumpDef.FaceShellDefinitions.Add
    Dim wireDef As WireDefinition
    Set wireDef = shellDef.WireDefinitions.Add
    ' ** Create a wire based on the outside loops of the selected face.
    ' Get the outer loop of the face.
    Dim outerLoop As EdgeLoop
    For Each outerLoop In testFace.EdgeLoops
        If outerLoop.IsOuterEdgeLoop Then
            Exit For
    Next
    ' Use the edge uses to step around the face.
    Dim lastVertexDef As VertexDefinition
    Set lastVertexDef = Nothing
    Dim coEdge As EdgeUse
    For Each coEdge In outerLoop.EdgeUses
        If lastVertexDef Is Nothing Then
            ' This is the first time through so get the starting vertex of the current edge use.
            If coEdge.IsOpposedToEdge Then
                Set lastVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StopVertex.Point)
            Else
                Set lastVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StartVertex.Point)
        ' Get the end vertex of the current edge use.
        Dim currentVertexDef As VertexDefinition
            Set currentVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StartVertex.Point)
        Else
            Set currentVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StopVertex.Point)
        ' If the geometry is an arc and the co-edge is opposed to the edge,
        ' the arc needs to be massaged so the start and end points are reversed.
        Dim geom As Object
        If coEdge.Edge.GeometryType = kCircularArcCurve And coEdge.IsOpposedToEdge Then
            Dim arc As Arc3d
            Set arc = coEdge.Edge.Geometry
            Dim center() As Double
            Dim axisVector() As Double
            Dim refVector() As Double
            Dim radius As Double
            Dim startAngle As Double
            Dim sweepAngle As Double
            Call arc.GetArcData(center, axisVector, refVector, radius, startAngle, sweepAngle)
            Set arc = tg.CreateArc3d(tg.CreatePoint(center(0), center(1), center(2)), _
                                     tg.CreateUnitVector(-axisVector(0), -axisVector(1), -axisVector(2)), _
                                     tg.CreateUnitVector(refVector(0), refVector(1), refVector(2)), _
                                     radius, startAngle + sweepAngle, sweepAngle)
            Set geom = arc
        Else
            Set geom = coEdge.Edge.Geometry
        ' Create a wire edge definition for the current edge.
        Call wireDef.WireEdgeDefinitions.Add(lastVertexDef, currentVertexDef, geom)
        ' Reset the last vertex to be the current vertex.
        Set lastVertexDef = currentVertexDef
    Next
    ' Create the wire body.
    Dim errors As NameValueMap
    Set errors = ThisApplication.TransientObjects.CreateNameValueMap
    Dim faceBody As SurfaceBody
    Set faceBody = bodyDef.CreateTransientSurfaceBody(errors)
    ' Draw the wire as client graphics to be able to visualize what's been calculated so far.
    ' This wire should overlay the selected face.
    Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, faceBody.Wires.Item(1), True)
    MsgBox "Wire created for outer boundary of selected face."
    ' Copy the wire body and translate it along the normal of the face.
    Dim transBody As SurfaceBody
    Set transBody = tBRep.Copy(faceBody)
    Dim transMatrix As Matrix
    Set transMatrix = tg.CreateMatrix
    Dim faceNormal As Vector
    Set faceNormal = GetFaceNormal(testFace).AsVector
    Call faceNormal.ScaleBy(0.5)
    Call transMatrix.SetTranslation(faceNormal)
    Call tBRep.Transform(transBody, transMatrix)
    ' Draw the translated wire as client graphics to be able to visualize what's been calculated so far.
    Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, transBody.Wires.Item(1), False)
    MsgBox "Copied and transformed wire created."
    ' Offset the transformed wire.
    Dim offsetWires As Wires
    Dim offsetDirection As UnitVector
    Set offsetWires = transBody.Wires.Item(1).OffsetPlanarWire(faceNormal.AsUnitVector, 0.25, kExtendCornerClosure)
    ' Draw the offset wire as client graphics to be able to visualize what's been calculated so far.
    Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, offsetWires.Item(1), False)
    MsgBox "Offset of wire created."
    ' Creat a ruled surface between the original wire and the offset.
    Dim ruled As SurfaceBody
    Set ruled = tBRep.CreateRuledSurface(faceBody.Wires.Item(1), offsetWires.Item(1))
    ' Create a base body feature of the ruled surface.
    Dim partDef As PartComponentDefinition
    Set partDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim baseBody As NonParametricBaseFeature
    Set baseBody = partDef.Features.NonParametricBaseFeatures.Add(ruled)
    ' Change the result work surface so it's not translucent.
    baseBody.SurfaceBodies.Item(1).Parent.Translucent = False
    MsgBox "Ruled surface between wires created and base body created."
End Sub
' Utility function that given a face returns a normal.  This is only useful
' for planar faces, since they have a consistent normal anywhere on the face.
Private Function GetFaceNormal(InputFace As Face) As UnitVector
    Dim eval As SurfaceEvaluator
    Set eval = InputFace.Evaluator
    ' Get the center of the parametric range.
    Dim center(1) As Double
    center(0) = (eval.ParamRangeRect.MinPoint.X + eval.ParamRangeRect.MaxPoint.X) / 2
    center(1) = (eval.ParamRangeRect.MinPoint.y + eval.ParamRangeRect.MaxPoint.y) / 2
    ' Calculate the normal.
    Dim normal() As Double
    Call eval.GetNormal(center, normal)
    ' Create a unit vector to pass back the result.
    Set GetFaceNormal = ThisApplication.TransientGeometry.CreateUnitVector(normal(0), normal(1), normal(2))
End Function
' Utility function that draws a Wire as client graphics.
Private Sub DrawWire(partDef As PartComponentDefinition, WireToDisplay As Wire, ClearExisting As Boolean)
    Dim trans As Transaction
    Set trans = ThisApplication.TransactionManager.StartTransaction(partDef.Document, "Wire display")
    Dim graphics As ClientGraphics
    On Error Resume Next
    Set graphics = partDef.ClientGraphicsCollection.Item("WireTest")
    If Err Then
        Set graphics = partDef.ClientGraphicsCollection.Add("WireTest")
    Else
        If ClearExisting Then
            graphics.Delete
    Dim node As GraphicsNode
    Set node = graphics.AddNode(1)
    Dim e As Edge
    For Each e In WireToDisplay.Edges
        Call node.AddCurveGraphics(e.Geometry)
    Next
    ThisApplication.ActiveView.Update
    trans.End
End Sub
