oh, you are in 3d environment.
I think you could maybe make it work by getting the axisVector. In my experience, Inventor seems to be following the opposite to the right hand rule... ? (make a thumbs up with your right hand. your thumb represent the axis direction, your fingers will then point to the rotational direction). But, at least it consistent.
I think your sweep angle will always be either CW or CCW around the axis vector.
use this function :
Arc3d.GetArcData( Center() As Double, AxisVector() As Double, RefVector() As Double, Radius As Double, StartAngle As Double, SweepAngle As Double )
for reference, here's the API example using this function to recreate a wire body of a selected part
Public Sub TaperFace()
Dim testFace As Face
Set testFace = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, "Select a planar face")
' Get the transient B-Rep and geometry objects.
Dim tBRep As TransientBRep
Set tBRep = ThisApplication.TransientBRep
Dim tg As TransientGeometry
Set tg = ThisApplication.TransientGeometry
' Create the top-level objects needed to construct a wire.
Dim bodyDef As SurfaceBodyDefinition
Set bodyDef = tBRep.CreateSurfaceBodyDefinition
Dim lumpDef As LumpDefinition
Set lumpDef = bodyDef.LumpDefinitions.Add
Dim shellDef As FaceShellDefinition
Set shellDef = lumpDef.FaceShellDefinitions.Add
Dim wireDef As WireDefinition
Set wireDef = shellDef.WireDefinitions.Add
' ** Create a wire based on the outside loops of the selected face.
' Get the outer loop of the face.
Dim outerLoop As EdgeLoop
For Each outerLoop In testFace.EdgeLoops
If outerLoop.IsOuterEdgeLoop Then
Exit For
End If
Next
' Use the edge uses to step around the face.
Dim lastVertexDef As VertexDefinition
Set lastVertexDef = Nothing
Dim coEdge As EdgeUse
For Each coEdge In outerLoop.EdgeUses
If lastVertexDef Is Nothing Then
' This is the first time through so get the starting vertex of the current edge use.
If coEdge.IsOpposedToEdge Then
Set lastVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StopVertex.Point)
Else
Set lastVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StartVertex.Point)
End If
End If
' Get the end vertex of the current edge use.
Dim currentVertexDef As VertexDefinition
Set currentVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StartVertex.Point)
Else
Set currentVertexDef = bodyDef.VertexDefinitions.Add(coEdge.Edge.StopVertex.Point)
End If
' If the geometry is an arc and the co-edge is opposed to the edge,
' the arc needs to be massaged so the start and end points are reversed.
Dim geom As Object
If coEdge.Edge.GeometryType = kCircularArcCurve And coEdge.IsOpposedToEdge Then
Dim arc As Arc3d
Set arc = coEdge.Edge.Geometry
Dim center() As Double
Dim axisVector() As Double
Dim refVector() As Double
Dim radius As Double
Dim startAngle As Double
Dim sweepAngle As Double
Call arc.GetArcData(center, axisVector, refVector, radius, startAngle, sweepAngle)
Set arc = tg.CreateArc3d(tg.CreatePoint(center(0), center(1), center(2)), _
tg.CreateUnitVector(-axisVector(0), -axisVector(1), -axisVector(2)), _
tg.CreateUnitVector(refVector(0), refVector(1), refVector(2)), _
radius, startAngle + sweepAngle, sweepAngle)
Set geom = arc
Else
Set geom = coEdge.Edge.Geometry
End If
' Create a wire edge definition for the current edge.
Call wireDef.WireEdgeDefinitions.Add(lastVertexDef, currentVertexDef, geom)
' Reset the last vertex to be the current vertex.
Set lastVertexDef = currentVertexDef
Next
' Create the wire body.
Dim errors As NameValueMap
Set errors = ThisApplication.TransientObjects.CreateNameValueMap
Dim faceBody As SurfaceBody
Set faceBody = bodyDef.CreateTransientSurfaceBody(errors)
' Draw the wire as client graphics to be able to visualize what's been calculated so far.
' This wire should overlay the selected face.
Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, faceBody.Wires.Item(1), True)
MsgBox "Wire created for outer boundary of selected face."
' Copy the wire body and translate it along the normal of the face.
Dim transBody As SurfaceBody
Set transBody = tBRep.Copy(faceBody)
Dim transMatrix As Matrix
Set transMatrix = tg.CreateMatrix
Dim faceNormal As Vector
Set faceNormal = GetFaceNormal(testFace).AsVector
Call faceNormal.ScaleBy(0.5)
Call transMatrix.SetTranslation(faceNormal)
Call tBRep.Transform(transBody, transMatrix)
' Draw the translated wire as client graphics to be able to visualize what's been calculated so far.
Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, transBody.Wires.Item(1), False)
MsgBox "Copied and transformed wire created."
' Offset the transformed wire.
Dim offsetWires As Wires
Dim offsetDirection As UnitVector
Set offsetWires = transBody.Wires.Item(1).OffsetPlanarWire(faceNormal.AsUnitVector, 0.25, kExtendCornerClosure)
' Draw the offset wire as client graphics to be able to visualize what's been calculated so far.
Call DrawWire(ThisApplication.ActiveDocument.ComponentDefinition, offsetWires.Item(1), False)
MsgBox "Offset of wire created."
' Creat a ruled surface between the original wire and the offset.
Dim ruled As SurfaceBody
Set ruled = tBRep.CreateRuledSurface(faceBody.Wires.Item(1), offsetWires.Item(1))
' Create a base body feature of the ruled surface.
Dim partDef As PartComponentDefinition
Set partDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim baseBody As NonParametricBaseFeature
Set baseBody = partDef.Features.NonParametricBaseFeatures.Add(ruled)
' Change the result work surface so it's not translucent.
baseBody.SurfaceBodies.Item(1).Parent.Translucent = False
MsgBox "Ruled surface between wires created and base body created."
End Sub
' Utility function that given a face returns a normal. This is only useful
' for planar faces, since they have a consistent normal anywhere on the face.
Private Function GetFaceNormal(InputFace As Face) As UnitVector
Dim eval As SurfaceEvaluator
Set eval = InputFace.Evaluator
' Get the center of the parametric range.
Dim center(1) As Double
center(0) = (eval.ParamRangeRect.MinPoint.X + eval.ParamRangeRect.MaxPoint.X) / 2
center(1) = (eval.ParamRangeRect.MinPoint.y + eval.ParamRangeRect.MaxPoint.y) / 2
' Calculate the normal.
Dim normal() As Double
Call eval.GetNormal(center, normal)
' Create a unit vector to pass back the result.
Set GetFaceNormal = ThisApplication.TransientGeometry.CreateUnitVector(normal(0), normal(1), normal(2))
End Function
' Utility function that draws a Wire as client graphics.
Private Sub DrawWire(partDef As PartComponentDefinition, WireToDisplay As Wire, ClearExisting As Boolean)
Dim trans As Transaction
Set trans = ThisApplication.TransactionManager.StartTransaction(partDef.Document, "Wire display")
Dim graphics As ClientGraphics
On Error Resume Next
Set graphics = partDef.ClientGraphicsCollection.Item("WireTest")
If Err Then
Set graphics = partDef.ClientGraphicsCollection.Add("WireTest")
Else
If ClearExisting Then
graphics.Delete
End If
End If
Dim node As GraphicsNode
Set node = graphics.AddNode(1)
Dim e As Edge
For Each e In WireToDisplay.Edges
Call node.AddCurveGraphics(e.Geometry)
Next
ThisApplication.ActiveView.Update
trans.End
End Sub
