Message 1 of 11
01:35 AM
I want to use the inventor file dialog to allow the user to navigate to select a folder.
I know I could use a windows folder dialog, but I prefer the interface of the file dialog.
You can do this using the windows file dialog by using a filter of "*.none" and then extracting the directory from the filename once the dialog "open" is pressed:
Using obj As New Windows.Forms.OpenFileDialog obj.Filter = "Directories|*.none" obj.CheckFileExists = False obj.CheckPathExists = False obj.InitialDirectory = startPath obj.Title = "Select Save Directory" obj.FileName = "Save Directory" If obj.ShowDialog = Windows.Forms.DialogResult.OK Then savePath = IO.Directory.GetParent(obj.FileName).FullName 'can extract directory from savePath End If End Using
Is there a way to do this with the inventor file dialog? I'd prefer to use the inventor file dialog because it already includes links to the work space and thumbnails etc.
