Faster Method for finding Components in Assembly
maxim.teleguz
Message 1 of 1
maxim.teleguz
here is my version that keeps track of your previous search so you can continue searching for the next one.
it is also smart enough to know when the occurrence is 1 of 1 to not continue searching for the next one.
it sets a temp file for the search if there are multiple occurrences then checks for the temp when the search is run next time.
Imports System
Imports System.Type
Imports System.Activator
Imports System.Buffer
Imports System.Runtime.InteropServices
Imports System.Runtime.GCSettings
Imports System.Windows.Forms
Imports System.Windows.Input
Imports Inventor
Imports Microsoft.Win32
Imports Microsoft.VisualBasic
Imports Microsoft.CSharp
Imports IO = System.IO
AddReference "System.Drawing.dll"
AddReference "System.Xml.dll"
AddReference "System.Windows.Forms.dll"
Sub Main()
    On Error Resume Next
    Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
    If Err.Number <> 0 Then
        MsgBox("Run in assembly only.")
        Exit Sub
    Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
    SendKeys.SendWait("{ESC}")
    AppActivate(ThisApplication.Caption)
    Dim tempFilePath As String = IO.Path.Combine(IO.Path.GetTempPath(), "ComponentSearchState.txt")
    Dim componentName As String = ""
    Dim occurrencesList As New List(Of ComponentOccurrence)
    Dim currentIndex As Integer = 0
    Dim continueSearch As Boolean = False
    ' Check if temp file exists
    If IO.File.Exists(tempFilePath) Then
        ' Read the state from the temp file
        Dim lines() As String = IO.File.ReadAllLines(tempFilePath)
        If lines.Length >= 2 Then
            componentName = lines(0)
            currentIndex = Integer.Parse(lines(1))
            ' Ask the user if they want to continue searching for the previous component
            Dim result As MsgBoxResult
            result = MsgBox("Do you want to continue searching for '" & componentName & "'?", MsgBoxStyle.YesNo, "Continue Search?")
            If result = MsgBoxResult.Yes Then
                ' Reconstruct the list of occurrences
                occurrencesList = FindAllOccurrencesByName(oAsmCompDef.Occurrences, componentName)
                continueSearch = True
            Else
                ' User wants to start a new search
                IO.File.Delete(tempFilePath)
        Else
            ' If file is corrupted, start a new search
    ' If not continuing previous search, start a new one
    If Not continueSearch Then
        componentName = InputBox("Enter the name of the component (you can enter a partial name):", "Component Name")
        If componentName = "" Then Exit Sub
        currentIndex = 0 ' Reset current index for new search
    If occurrencesList.Count = 0 Then
        MsgBox("No occurrences found for '" & componentName & "'.", vbCritical, "")
        If IO.File.Exists(tempFilePath) Then IO.File.Delete(tempFilePath)
        Exit Sub
    ' Check if current index is within the range
    If currentIndex >= occurrencesList.Count Then
        MsgBox("No more occurrences found for '" & componentName & "'.", vbInformation, "")
        Exit Sub
    ' Get the current occurrence
    Dim oOcc As ComponentOccurrence = occurrencesList(currentIndex)
    ' Select the occurrence directly
    Dim oSS As SelectSet = oDoc.SelectSet
    oSS.Clear()
    oSS.Select(oOcc)
    ' Optionally, zoom to the selected occurrence
    ' ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute()
    ' ThisApplication.ActiveView.Fit(True)
    ' Expand and collapse the Origin node if needed
    ExpandCollapseOriginNode(oOcc)
    ' Increment the index
    currentIndex += 1
    ' Check if there are more occurrences
    If occurrencesList.Count > 1 And currentIndex < occurrencesList.Count Then
        ' Save the state to the temp file for the next search
        Dim linesToWrite As String() = {componentName, currentIndex.ToString()}
        IO.File.WriteAllLines(tempFilePath, linesToWrite)
        MsgBox("Found occurrence " & currentIndex & " of " & occurrencesList.Count & " for '" & componentName & "'.", vbInformation, "Component Search")
    Else
        ' No more occurrences, delete the temp file and inform the user
        MsgBox("Found occurrence " & currentIndex & " of " & occurrencesList.Count & " for '" & componentName & "'. Search completed.", vbInformation, "Component Search")
End Sub
Function FindAllOccurrencesByName(oOccurrences As ComponentOccurrences, componentName As String) As List(Of ComponentOccurrence)
    For Each oOcc As ComponentOccurrence In oOccurrences
        If oOcc.Name.Contains(componentName) Then
            occurrencesList.Add(oOcc)
        If oOcc.SubOccurrences.Count > 0 Then
            occurrencesList.AddRange(FindAllOccurrencesByName(oOcc.SubOccurrences, componentName))
    Next
    Return occurrencesList
End Function
Sub ExpandCollapseOriginNode(oOcc As ComponentOccurrence)
    Dim oDoc As Document = oOcc.Parent.Document
    Dim oPane As BrowserPane = oDoc.BrowserPanes.Item("AmBrowserArrangement")
    Dim oOccNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc)
    If oOccNode Is Nothing Then Exit Sub
    Dim oFMNode As BrowserNode = GetBrowserNodeByLabel(oOccNode, "Folded Model")
    Dim oOriginNode As BrowserNode = Nothing
    If IsNothing(oFMNode) Then
        oOriginNode = GetBrowserNodeByLabel(oOccNode, "Origin")
    Else
        oOriginNode = GetBrowserNodeByLabel(oFMNode, "Origin")
    If Not IsNothing(oOriginNode) Then
        oOriginNode.Expanded = True
        oOriginNode.Expanded = False
        oOccNode.Expanded = False
End Sub
Function GetBrowserNodeByLabel(oStartBNode As BrowserNode, oLabel As String) As BrowserNode
    If IsNothing(oStartBNode) Then Return Nothing
    ' Look at this level first
    For Each oNode As BrowserNode In oStartBNode.BrowserNodes
        If oNode.BrowserNodeDefinition.Label = oLabel Then Return oNode
    Next
    ' Step down into lower levels
        If oNode.BrowserNodes.Count > 0 Then
            Dim resultNode As BrowserNode = GetBrowserNodeByLabel(oNode, oLabel)
            If Not IsNothing(resultNode) Then Return resultNode
    Next
    Return Nothing
End Function
Replies (0)
