Fail to get textual names of Browser Node types with ToString in iLogic
Maxim-CADman77
Maxim-CADman77
I'd like to know how can I get textual names for types of Browser Nodes presented in Part's browser (Model Tab).
When I add "ToString" after the Type query I still get numeric value like:
The iLogic code I'm using is:
Dim oIPT As PartDocument=ThisDoc.Document
Dim MsgBody As String
For Each oNode In oIPT.BrowserPanes("PmDefault").TopNode.BrowserNodes
	If oNode.Visible Then
		MsgBody &= oNode.BrowserNodeDefinition.Label & vbCrLf
		If Not oNode.NativeObject Is Nothing Then
			MsgBody &= "       Type : " & oNode.NativeObject.Type.ToString & vbCrLf
		End If
	End If
Next
MsgBox (MsgBody,,"Node types are:")
Exit Sub
The issue described was reproduced in Inventor 2020.2.1
Please vote for Inventor-Idea Text Search within Option Names
JhoelForshav
Hi @Maxim-CADman77
Are you looking for something like this? :slightly_smiling_face:
Sub Main
	Dim oIPT As PartDocument = ThisDoc.Document
				MsgBody &= "       Type : " & GetObjectEnum(oNode.NativeObject.Type.ToString) & vbCrLf
			End If
		End If
	Next
	MsgBox(MsgBody, , "Node types are:")
	Exit Sub
End Sub
Function GetObjectEnum(oValue)
	Dim oEnumType As EnumType
	oEnumType = ThisApplication.TestManager.GetEnumType("ObjectTypeEnum")
	oEnumType.Value = 0
	Dim oName As String
	Dim index As Integer
	index = 0
	Do While index < oEnumType.Count
		If oEnumType.Value = oValue
			oName = oEnumType.ValueName
			Exit Do
		End If
		oEnumType.MoveNext
		index = index + 1
	Loop
	Return oName
End Function
Maxim-CADman77
Thank for the suggestion, but I also got the single-line solution (https://forums.autodesk.com/t5/inventor-customization/api-return-enumerator-name-instead-of-numeric-...).
InstedOf:
The
[Enum].GetName(GetType(ObjectTypeEnum), oNode.NativeObject.Type)
...should be used.
