Factory: Filtering parameteres (Asset properties)
Is it possible to block options under asset properties? Sort of like a filtering option
Example:
If I have two key parameters
1) Wheel (Options: Single and Double)
2) WheelDiameter (Options: Ø100, Ø200, Ø300, Ø400)
If I select Single (Wheel), only Ø100 and Ø400 are selectable. And when I select Double I can only choose between Ø200 and Ø300
It's to diasble a user from selecting a Single wheel with a Ø200 diameter etc.
Sergio.D.Suárez
Hi, it is not necessary that you have two parameters, you can have only one, and then with an ilogic load values according to this parameter. In the example of ilogic that I share I create a list with the values you mention.
Dim oValueList As New ArrayList
Dim oValue As String
If Wheel = "Single" Then
	oValueList.Add("Ø100")
	oValueList.Add("Ø400")
	oValue = InputListBox("select the appropriate diameter", oValueList, "Ø100", "Ilogic", "Available Selections")
Else
	oValueList.Add("Ø200")
	oValueList.Add("Ø300")
End If
Maybe some similar approach can be useful, regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Instead of a pop up, could the value be added to an "empty" parameter.
Let's say I created an empty parameter called "Size", and if i select Single, the sizes Ø100 and Ø400 gets added to the Size parameter (multi value) for me to choose from, and if I select Double, the sizes Ø200 and Ø300 are added and Ø100 and Ø400 removed
