Extrude each profile in a sketch
ngocson8335
ngocson8335
Hello Everyone,
My name is Son. I am trying to extrude each profile in a sketch with new solid but I can not find the API to do that. Please help me in this case.
Screenshot:
Many thanks.
Ngoc Son
Autodesk User
WCrihfield
This is regular iLogic (VB.net), not API (VBA), but its easily convertible by adding a 'Set',  and a 'Call' or few in there.  After finding the Sketch, it sets it as Shared, so that it can be used by multiple ExtrudeFeatures if needed.  Then it basically just goes another step deeper in the Profile to its ProfileFaths, checks whether they are 'Closed' or not, then sets its '.AddsMaterial' property.
I think you can play around with this idea to achieve your goal.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oCompDef.Sketches.Item(1)
oSketch.Shared = True
Dim oProfiles As Profiles = oSketch.Profiles
For Each oProfile As Profile In oPrfiles
	If oProfile.Count > 1 Then
		For i = 1 To oProfile.Count
			If oProfile.Item(i).Closed = True Then
				oProfile.Item(i).AddsMaterial = True
		Next
	oProfiles.AddForSolid ' You can modify the Optional Parameters of this if needed.
	Dim oExtFeats As ExtrudeFeatures = oCompDef.Features.ExtrudeFeatures
	Dim oExtrudeDef As ExtrudeDefinition
	oExtrudeDef = oExtFeats.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kNewBodyOperation)
	oExtrudeDef.SetDistanceExtent(10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
	Dim oExtrude As ExtrudeFeature
	oExtrude = oExtFeats.Add(oExtrudeDef)
Next
Check out the following link for additional info.
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-5A9FA7CB-1EB9-4849-BB9D-11AD01F3DBF6
And this example
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-E9592972-C31C-4800-9699-C069E5C92BC3
Wesley Crihfield
(Not an Autodesk Employee)
ngocson8335
Hello Mr.
Thanks for your help.
I just put your code to the Visual Studio but after running, the first solid did not show on the model display and it is stopped for the second time.
Error screenshot:
Many thanks,
Ngoc Son
Ngoc Son
Autodesk User
