Extract the last folder before file as String
danny.lewisA9QBW
danny.lewisA9QBW
I want to get the last folder used in the filepath and extract it as a string:
eg.  C:\Vault\WorkingFolder\Folder1\Folder2\Folder3\Part.ipt
extract only: Folder3
Can someone help me out with this? I feel like I'm overthinking it and it should be like 2-3 lines of code.
Replies (9)
bradeneuropeArthur
Hi.
With ilogic, vba, vb.net or what?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
danny.lewisA9QBW
iLogic.
bradeneuropeArthur
Dim d As System.IO.DirectoryInfo
d = New System.IO.DirectoryInfo("C:\Vault\WorkingFolder\Folder1\Folder2\Folder3\Part.ipt")
Dim s As String
s = d.Name
MsgBox (s)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
or
Dim d As System.IO.FileInfo
d = New System.IO.FileInfo("C:\Vault\WorkingFolder\Folder1\Folder2\Folder3\Part.ipt")
Dim s As String
s = d.Directory.Name
MsgBox (s)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
danny.lewisA9QBW
I'm getting an error message with the d.Directory.Name. The d.Name just gave the filename (as I'm sure you realized)
MsgBox("Directory "& ThisDoc.PathAndFileName(False))
d = New System.IO.DirectoryInfo(ThisDoc.PathAndFileName(False))
Dim s As String
MsgBox ("String = " & s)
bradeneuropeArthur
Amd the second option with fileinfo?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
JhoelForshav
@danny.lewisA9QBW
How about this?
Dim oFolders() As String = System.IO.Path.GetDirectoryName(ThisDoc.PathAndFileName).Split("\")
Dim oLastFolder As String = oFolders(oFolders.Count - 1)
MsgBox(oLastFolder)
danny.lewisA9QBW
and bonus... you did the whole thing in 2-3 lines 😛
JhoelForshav
To be fair, @bradeneuropeArthur 's first suggestion works great!! You can even compress that into this short line:
MsgBox(New System.IO.FileInfo(ThisDoc.PathAndFileName).Directory.Name)
Or to store it in variable:
Dim oFolder As String = New System.IO.FileInfo(ThisDoc.PathAndFileName).Directory.Name
MsgBox(oFolder)
