Announcements
Extract bendID or bendorder number from flatpattern
Hello Does anyone know how to extract the bend ID's and Bend order number from the 3D sheetmetal part.
Counting bends does not return the same number at the Bend ID i a 2D bend table.
I want to get the highest bendorder number from the sheetmetal part.
maybe counting bendlines does the trick.
Can some one please help.
Regards Kent boettger.
Replies (7)
Vladimir.Ananyev
Hi Kent,
could you please upload your SheetMetal model for test purposes?
It would be great if you add some description as well (what you want to get from the model).
thanks,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Hello Vladimir,
Here is an example of a part / drawing and a description on what i want to do, extract and why.
hope you can help.
regards. Kent boettger
Any help here? Please.
Vladimir.Ananyev
 Here is my test for the flange feature #1 in your sheet metal model.
Sub Test()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As SheetMetalComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oFlangeFeatures As FlangeFeatures
    Set oFlangeFeatures = oDef.Features.FlangeFeatures
    Debug.Print "FlangeFeatures.Count = " & oFlangeFeatures.Count
    ' Get the flange feature.
    Dim oFlange As FlangeFeature
    Set oFlange = oFlangeFeatures.Item(1)
    ' Position the end of part marker to just before this feature so the
    ' edges are in their original state.
    Call oFlange.SetEndOfPart(True)
    Dim oFlangeDef As FlangeDefinition
    Set oFlangeDef = oFlange.Definition
    Dim oEdge As Edge
    Set oEdge = oFlangeDef.Edges.Item(1)
    Dim Length As Double
        'calculation of the edge length
        Dim oCurveEval As CurveEvaluator
        Set oCurveEval = oEdge.Evaluator
        Dim MinParam As Double
        Dim MaxParam As Double
        Call oCurveEval.GetParamExtents(MinParam, MaxParam)
        Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, Length)
    Debug.Print "Length, cm = " & Length
    ' Set the stop node back to the bottom of the browser.
    Call oDef.SetEndOfPartToTopOrBottom(False)
    Beep
End Sub
Results:
FlangeFeatures.Count = 3
Length, cm = 10
Hope this could help.
cheers,
Vladimir Ananyev
Hello Vladimir.
This is nice but actually not what i am locking for?
your code will not work when we have cosmetic bendlines in the model.?
here is my code so fare.
I want to be able to get the bend order number attached to each bendline in the model.
this will give us the rigth bend count. see attached model, picture and code.
The bend count on the attached model will be 9, this is wrong.
But the highest bend order number in the flatpattern is 7, this is right
I want to read out the highest bend order number "7".
please help.
regards kent boettger
        Dim m_invapp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        ' Set a reference to the sheet metal document.
        ' This assumes a part document is active.
        Dim oPartDoc As PartDocument
        oPartDoc = m_invapp.ActiveDocument
        ' Make sure the document is a sheet metal document.
        If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            MsgBox("A sheet metal document must be open.")
            Exit Sub
        Dim oSheetMetalCompDef As SheetMetalComponentDefinition
        oSheetMetalCompDef = oPartDoc.ComponentDefinition
        If (Not oSheetMetalCompDef.HasFlatPattern) = True Then
            oSheetMetalCompDef.Unfold()
        Dim oFlatPattern As FlatPattern
        oFlatPattern = oSheetMetalCompDef.FlatPattern
        Dim oBendResults As FlatBendResults = oFlatPattern.FlatBendResults
        MsgBox("Bendlines = " & oBendResults.Count / 2)
        Dim oTotalBends As Integer = oBendResults.Count / 2
        Dim oBendresult As FlatBendResult
        For Each oBendresult In oBendResults
            ' Here i want to get the bend order number attached to the bendline?
            ' but i dont know how to do this.
            Dim oBendordernumber As Integer = oBendresult.GetBendOrder()
        Next
adam.nagy
Autodesk Support
Autodesk Support
Hi Kent,
So is this all that's missing for you?
        Dim oBendorderNumber As Long
        Dim oBendorderSource As BendOrderSourceTypeEnum
        Call oBendresult.GetBendOrder(oBendorderNumber, oBendorderSource)
Cheers,
Adam Nagy
Autodesk Platform Services
Thanks Adam, Just what i was looking for.
        'Dim oTotalBends As Integer = oBendResults.Count / 2 ( This was wrong )
        Dim oBendCountReal As Long = Nothing
            Dim oBendordernumber As Long
            Call oBendresult.GetBendOrder(oBendordernumber, oBendorderSource)
            If oBendordernumber > oBendCountReal Then
                oBendCountReal = oBendordernumber
        Next
        'MsgBox("oBendCountReal = " & oBendCountReal)
        Return oBendCountReal
