Hello Vladimir.
This is nice but actually not what i am locking for?
your code will not work when we have cosmetic bendlines in the model.?
here is my code so fare.
I want to be able to get the bend order number attached to each bendline in the model.
this will give us the rigth bend count. see attached model, picture and code.
The bend count on the attached model will be 9, this is wrong.
But the highest bend order number in the flatpattern is 7, this is right
I want to read out the highest bend order number "7".
please help.
regards kent boettger
Dim m_invapp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
' Set a reference to the sheet metal document.
' This assumes a part document is active.
Dim oPartDoc As PartDocument
oPartDoc = m_invapp.ActiveDocument
' Make sure the document is a sheet metal document.
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox("A sheet metal document must be open.")
Exit Sub
End If
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
oSheetMetalCompDef = oPartDoc.ComponentDefinition
If (Not oSheetMetalCompDef.HasFlatPattern) = True Then
oSheetMetalCompDef.Unfold()
End If
Dim oFlatPattern As FlatPattern
oFlatPattern = oSheetMetalCompDef.FlatPattern
Dim oBendResults As FlatBendResults = oFlatPattern.FlatBendResults
MsgBox("Bendlines = " & oBendResults.Count / 2)
Dim oTotalBends As Integer = oBendResults.Count / 2
Dim oBendresult As FlatBendResult
For Each oBendresult In oBendResults
' Here i want to get the bend order number attached to the bendline?
' but i dont know how to do this.
Dim oBendordernumber As Integer = oBendresult.GetBendOrder()
Next
