Morning all
I would like to be able to run an external rule I have created that is attached called "Generator" from another rule called "Run Generator on all". The "Run Generator on all" will be run on the top level assembly and will cycle through all my assemblies and parts and run the "Generator" rule on each Assembly and Part.
Problem I have is that when each Assembly and Part is opened via the "Run Generator on all" rule the "Generator" rule is not running on the parts or assemblies. I'm sure its do do with the 1st few lines of the "Generator" rule but I cant work out how to change this. The "Generator" rule will also need to work when run directly from any Assembly or Part.
I know the "Generator" rule is not the cleanest but it works for me.
Thanks everyone
Running Inventor 2022
Donald
