This is definitely possible and not that difficult. Here is some code I put together from something similar I had. It will prompt for the two quantities and multipy them, if the flat pattern doesn't exist yet it will create it, and then it will save the dxf in the same folder as the part with "-(totalquantity) added to the file name. Let me know how it works for you.
Public Sub Export_DXF()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveEditDocument
If (oDoc.FullDocumentName <> oDoc.FullDocumentName) Then
MsgBox "Can't export while editing a part in an assembly"
Exit Sub
ElseIf (oDoc.ComponentDefinition.Type <> kSheetMetalComponentDefinitionObject) Then
MsgBox "Not a sheet metal part Sorry."
Exit Sub
End If
Dim BomQty As Integer
BomQty = InputBox(Prompt:="Enter Bom Quantity", Title:="Bom Quantity")
Dim AsmQty As Integer
AsmQty = InputBox(Prompt:="Enter Assembly Quantity", Title:="Assembly Quantity")
Dim TotQty As Integer
TotQty = BomQty * AsmQty
'If flat pattern doesn't exist, create it and return to folded view
If (oDoc.ComponentDefinition.FlatPattern Is Nothing) Then
Dim oDef As ControlDefinition
oDoc.ComponentDefinition.Unfold
Set oDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartSwitchRepresentationCmd")
oDef.Execute
End If
' Get the DataIO object.
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
' Build the string that defines the format of the DXF file.
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Outer&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up;IV_Arc_Centers"
' Create the DXF file.
oDataIO.WriteDataToFile sOut, full_path(oDoc.FullFileName) & filename_noext(oDoc.FullFileName) & "-" & TotQty & ".dxf"
End Sub
Function filename_noext(spth As String)
'Returns filename without extension from full path
If (spth <> "") And (InStr(spth, ".")) And (InStrRev(spth, "\") < InStrRev(spth, ".")) Then
filename_noext = Mid(spth, InStrRev(spth, "\") + 1, InStrRev(spth, ".") - InStrRev(spth, "\") - 1)
ElseIf (spth <> "") And Not (InStr(spth, ".")) Then
filename_noext = Mid(spth, InStrRev(spth, "\", Len(spth)) + 1, Len(spth))
Else:
filename_noext = ""
End If
End Function
Function full_path(spth As String)
'Returns full path minus filename, trailing slash is included
If spth <> "" Then
full_path = Left(spth, Len(spth) - (Len(spth) - InStrRev(spth, "\")))
Else:
full_path = ""
End If
End Function
