Exporting files with revision level in the filename
I'm trying to see if there is a way to use Task Scheduler or something along those lines to be able to export Inventor .IDW files to a .dxf with the Inventor revision level in the name.  For example export Inventor_part.idw to Inventor_part_REVA.dxf.  I'm currently running Autodesk Inventor Professional 2015.  If this isn't directly possible to do in Task Scheduler, can this be done through the .ini file for the file export, or a .xml file for the customization feature?  I would appreciate any help I can get.
MechMachineMan
Not too sure if there is something built in, but there are definitely lots of iLogic rules around here on the form that do the same thing or are close to doing it.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
omartin
You can have a look at this, it is a method to create custom tasks using the task scheduler.
http://beinginventive.typepad.com/being-inventive/2011/11/how-to-create-a-custom-task-in-task-schedu...
Was my reply Helpful ? send a Kudos or accept as solution
