Announcements
Export several partlist to one excel book
EMVC
EMVC
Hello
is there a vba thats can export several parts list to one excel book
Lets say may poject in one order is based on 10 idw files , can that easealy be exported to one excel book not sheet
one partlist one one tab
Replies (12)
HideoYamada
I made sample code that collect the BOMs of the drawing documents which are opened.
Option Explicit
Private Const TempWorkBookName = "TempWorkBook.xlsx"
Private oExcelApp As Excel.Application
Private TempWorkbookFullName As String
Public Sub CollectOpenedIdwBOMs()
    ' Init WSH and temp path
    Dim WSH As Variant
    Set WSH = CreateObject("WScript.Shell")
    TempWorkbookFullName = WSH.SpecialFolders("Desktop") & "\" & TempWorkBookName
    ' Setup Excel
    Set oExcelApp = CreateObject("Excel.Application")
    oExcelApp.Visible = True
    oExcelApp.DisplayAlerts = False
    Dim oWorkbook As Workbook
    Set oWorkbook = oExcelApp.Workbooks.Add
    ' Create AssyDoc collection
    Dim oAssyDocs As ObjectCollection
    Set oAssyDocs = CreateAssyDocs
    ' Collect BOMs into one workbook
    MsgBox "Start Step 1"
    CollectBOMsFromDocs oAssyDocs, oWorkbook
    ' Combine worksheets into one sheet
    MsgBox "Start Step 2"
    CombineWorksheets oWorkbook
    ' end
    oExcelApp.DisplayAlerts = True
    Set oExcelApp = Nothing
    MsgBox "End"
End Sub
Private Function CreateAssyDocs() As ObjectCollection
    Set CreateAssyDocs = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oDoc As Document
    For Each oDoc In ThisApplication.Documents
        If TypeOf oDoc Is DrawingDocument Then
            Dim oDrawingDoc As DrawingDocument
            Set oDrawingDoc = oDoc
            Dim oRefedDoc As Document
            Set oRefedDoc = oDrawingDoc.ActiveSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
            If TypeOf oRefedDoc Is AssemblyDocument And oRefedDoc.ComponentDefinition.BOM.StructuredViewEnabled Then
                CreateAssyDocs.Add oRefedDoc
    Next oDoc
End Function
Private Sub CollectBOMsFromDocs(oAssyDocs As ObjectCollection, oWorkbook As Workbook)
    Dim oAssyDoc As AssemblyDocument
    For Each oAssyDoc In oAssyDocs
        ExportBOMAsWorkbook oAssyDoc
        Dim oTempWorkbook As Workbook
        Set oTempWorkbook = oExcelApp.Workbooks.Open(TempWorkbookFullName)
        oTempWorkbook.Sheets(1).Move After:=oWorkbook.Sheets(1)
        Kill TempWorkbookFullName
    Next oAssyDoc
End Sub
Private Sub CombineWorksheets(oWorkbook As Workbook)
    If oWorkbook.Sheets.Count <= 1 Then
        Exit Sub
    ' Copy title line
    oWorkbook.Sheets(2).Rows(1).Copy oWorkbook.Sheets(1).Rows(1)
    ' Copy all sheets into one
    Dim oSheet As WorkSheet
    Dim rowIndex As Integer
    rowIndex = 2
    While oWorkbook.Sheets.Count > 1
        Dim r As Range
'        Set r = oWorkbook.Sheets(2).Cells(2, 1)
'        Set r = Range(r, r.End(xlDown)).EntireRow
        Set r = oWorkbook.Sheets(2).Rows("2:" & oWorkbook.Sheets(2).Cells(2, 1).End(xlDown).Row)
        r.Copy oWorkbook.Sheets(1).Cells(rowIndex, 1)
        rowIndex = rowIndex + r.Rows.Count
        oWorkbook.Sheets(2).Delete
    Wend
End Sub
Private Sub ExportBOMAsWorkbook(oAssyDoc As AssemblyDocument)
    Call oAssyDoc.ComponentDefinition.BOM.BOMViews("Structured").Export(TempWorkbookFullName, kMicrosoftExcelFormat, oAssyDoc.DisplayName)
End Sub
See the video also :
https://autode.sk/2mzItnR
Is this code helping you?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
EMVC
Hello
It seems that i have done something , becouse it is not workingPrint alt+F8.jpgPrint.JPGSkriv ut.JPG
EMVC
Hello
and thank you i look at video and it seems like what i want
HideoYamada
Hi EMVC,
These four lines must be deleted.
(They don't exist in original code which I posted.)
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
EMVC
I can not understand what i do wrong, i have placed the code under Module 1
HideoYamada
You must add Reference to Excel Object Library in Inventor.
VBA Editor -> Tools -> References -> :
Freeradical
 Hideo Yamada
EMVC
Hello
Thank you now i getting somwhere, but i get data from Bill of materials not Partlist, se picturesGetting this.JPGPartList.JPG
EMVC
Hello
HideoYamada
Hi EMVC,
If you need Part List on the drawing document, delete all the codes and insert follows :
Option Explicit
Public Sub CollectOpenedIdwPartLists()
    Dim WSH As Variant
    ' Setup Excel
    ' Create DrawingDoc collection
    Dim oDrawingDocs As ObjectCollection
    Set oDrawingDocs = CreateDrawingDocs
    CollectPartListsFromDocs oDrawingDocs, oWorkbook
    ' end
    MsgBox "End"
End Sub
Private Function CreateDrawingDocs() As ObjectCollection
    Set CreateDrawingDocs = ThisApplication.TransientObjects.CreateObjectCollection
            If oDrawingDoc.ActiveSheet.PartsLists.Count > 0 Then
                CreateDrawingDocs.Add oDrawingDoc
    Next oDoc
End Function
Private Sub CollectPartListsFromDocs(oDrawingDocs As ObjectCollection, oWorkbook As Workbook)
    For Each oDrawingDoc In oDrawingDocs
        ExportPartListAsWorkbook oDrawingDoc
    Next oDrawingDoc
End Sub
        Exit Sub
    ' Copy title line
    rowIndex = 2
        Dim r As Range
    Wend
End Sub
Private Sub ExportPartListAsWorkbook(oDrawingDoc As DrawingDocument)
    oDrawingDoc.ActiveSheet.PartsLists(1).Export TempWorkbookFullName, kMicrosoftExcel, oDrawingDoc.DisplayName
End Sub
And if you don't need to combine lists into one sheet, comment out following codes or simply delete them :
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
EMVC
Hello
Thank you , absoulte genius
smichels
Need help with this one.
I tried to use this example code and get a blank excel document and errors.
Please see attached
smichels
Disregard my last post.
The macro starts a blank excel workbook step1, step2 and end message works but nothing populates in excel work book.
Any idea's would be helpful
