Export picture (PNG) - ilogic - with variable Name
HI all,
    i use this Code, for Export Model to PNG Picture:
Option Explicit On
Dim m_Doc As Inventor.Document
m_Doc = ThisDoc.Document
If m_Doc.DocumentType <> kAssemblyDocumentObject _
   And m_Doc.DocumentType <> kPartDocumentObject Then
   MessageBox.Show("File is not a model.", "iLogic")
   Return 'exit rule
End If
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If m_Doc.DocumentType = kPartDocumentObject Then
  m_Camera.SceneObject = DirectCast(m_Doc, PartDocument).ComponentDefinition
Else
  m_Camera.SceneObject = DirectCast(m_Doc, AssemblyDocument).ComponentDefinition
End If
'm_Camera.Perspective = True
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
Dim oFileName As String = ThisDoc.FileName(False)
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
Dim m_PrevMode As DisplayModeEnum
Dim m_Disp3D As Boolean
m_Disp3D = ThisApplication.DisplayOptions.Show3DIndicator
m_PrevMode = ThisApplication.DisplayOptions.NewWindowDisplayMode
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kSHADEDWITHEDGESRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Try
m_Camera.SaveAsBitmap("C:\Export\" & oFileName & ".png", 2970, 2100, m_TO.CreateColor(255,255,255))
Finally
ThisApplication.DisplayOptions.NewWindowDisplayMode = m_PrevMode
ThisApplication.DisplayOptions.Show3DIndicator = m_Disp3D
End Try
But i have Problem with export more Picture from one Model -> is overwriten. I need edit code and add with variable Name (Name_001 - Name_999).
Please can me help sameone?
TY.
mcgyvr
Well.. you have some options..
Do you want to prompt for the file name?
Do you want the file name to just be the models file name + png?
You really can't do a variable as there isn't a method to store the "last known state" that I know of short of exporting to a file and reading that file over each time but thats a bit silly for such a simple task..
Try this..
Option Explicit On
   Return 'exit rule
End If
Else
End If
m_Camera.Fit
Dim myimagename As String m_Disp3D = ThisApplication.DisplayOptions.Show3DIndicator m_PrevMode = ThisApplication.DisplayOptions.NewWindowDisplayMode ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering ThisApplication.DisplayOptions.Show3DIndicator = False Try myimagename = InputBox("Enter a file name", "Image File Name", "Name01.png") m_Camera.SaveAsBitmap("C:\Export\" & myimagename, 2970, 2100, m_TO.CreateColor(255,255,255)) Finally ThisApplication.DisplayOptions.NewWindowDisplayMode = m_PrevMode ThisApplication.DisplayOptions.Show3DIndicator = m_Disp3D End Try
I need only save more screenshots (Image) from different sides, unter Name: Model_001, Model_002, Model_003 - Model_XXX
Model = Part or Assembly that is for me FileName
1-click on ilogic rule = 1 new screen shots with with a suffix _001 - XXX, iLogic itself saves other sreenshots under a new name (verify it free suffix)
Something like here on other forum at STEP file (link is forbidden) :
Option Explicit On
' Start of iLogic code *******************************************
Stepfilename = ThisDoc.PathAndFileName(False)
Counter = 0
FileExists = True
'check to see if the file to be exported already exists
Do While FileExists
    ' Define name of exported file - note a .stp file extension
    ' Is currently being used. In this example I am exporting a Step file
    CurrentFile = Stepfilename & "_V" & Counter & ".stp"
    If Dir(CurrentFile) <> "" Then ' The file does exist
        Counter += 1
        FileExists = True
    Else
        SaveAs = MessageBox.Show("Export file as '" & CurrentFile & _
        "'?", "Cadline iLogic", _
        MessageBoxButtons.YesNo, MessageBoxIcon.Question, _
        MessageBoxDefaultButton.Button1)
        If SaveAs = vbNo Then
            Return
        Else ' User says continue
            FileExists = False
        End If
    End If
Loop
' Put your export or 'save as' code in here ***********************
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument _
, oContext, oOptions) Then
    oOptions.Value("ApplicationProtocolType") = 3
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    ' Set export name of STEP file
    oData.FileName = CurrentFile
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext _
, oOptions, oData)
End If
' End of export code ***********************************************
' Ask user if they want to open the export folder
OpenFolder = MessageBox.Show("Export successful! " & _
"- open containing folder now?", "Cadline iLogic", _
MessageBoxButtons.YesNo, _
MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
If OpenFolder = vbYes Then
    Process.Start("explorer.exe", ThisDoc.Path)
    'Return
End If
' End of iLogic code **************************************************
bradeneuropeArthur
Could this help you?
https://forums.autodesk.com/t5/inventor-customization/transparent-background/m-p/7761624#M80096
Arthur Knoors
Autodesk Affiliations:
this no ...
my new functional code:
oView = ThisApplication.ActiveView
Dim originalSchema As String
originalSchema = ThisApplication.ActiveColorScheme.Name
Dim originalBkg As BackgroundTypeEnum
originalBkg = ThisApplication.ColorSchemes.BackgroundType
ThisApplication.ColorSchemes.Item("Prezentace").Activate
ThisApplication.ColorSchemes.BackgroundType = 52737 'kOneColorBackgroundType
Dim originSetOff as Boolean
originSetOff = False
If ThisApplication.DisplayOptions.Show3DIndicator Then
 originSetOff = True
End If
Dim picName As String = "C:\Export\" + ThisDoc.FileName(False) + Now.toString("-yyMMddHHmmss") 'timestamp
Call oView.SaveAsBitmap(picName & ".png", oView.Width, oView.Height)
If originSetOff Then
 ThisApplication.DisplayOptions.Show3DIndicator = True
End If
ThisApplication.ColorSchemes.Item(originalSchema).Activate
ThisApplication.ColorSchemes.BackgroundType = originalBkg
'MsgBox(ThisDoc.PathAndFileName(True) & ".png")
