Export Parts List/BOM to Excel Using iLogic & Template
Hello all,
I've scoured these forums yet there are no solutions to the threads on this topic.  The community here is great and have helped me on a number of occasions, so hopefully we'll get this sorted not only for me, but for others who search the forums in the future!
We currently have two parts lists on our drawings.  One is a compact "reference" parts list which sits on page 1.  The other is a full material list which we place off-sheet.  The off-sheet material list is what we need to export to Excel for our Material Allocation department - as they assign their data to the three columns and don't have access to Inventor.
So for now we have to do the following:
  1. Place both parts lists in the drawing
  2. Right-click on the large material list and click "Export"
  3. Navigate to the destination folder
  4. Assign the template using the "Options" button
  5. Save the material list
I like iLogic and how it saves time.  I have seen a code from 2011 from @Anonymous_Waguespack which seems to do the trick on his example, however I cannot get it to work.  It has been pasted on these forums many times but I'll paste it again in post #2 so I don't clog this post up.
Ideally I'd just make a code and reference to it in a form so users just have to click a button.
Can anyone help with this problem?
Replies (10)
This is the code I tried to copy:
'get the path and name of the drawing file
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'define oDoc
oDoc = ThisDoc.Document
'specify the drawing sheet
oSheet = oDoc.Sheets("Sheet:1") ' sheet by name
'oSheet = oDoc.Sheets(1) ' first sheet
 ' say there is a Partslist on the sheet.
oPartslist = oSheet.PartsLists(1)
' create a new NameValueMap object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'specify an existing template file
'to use For formatting colors, fonts, etc
oOptions.Value("Template") = "C:\Temp\PartListExport.xls"
'specify the columns to export
oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
'specify the start cell
oOptions.Value("StartingCell") = "A3"
'specify the XLS tab name
'here the file name is used
oOptions.Value("TableName") = ThisDoc.FileName(False) 'without extension
'choose to include the parts list title row
'in this example "Ye Old List of Parts" is written to the StartingCell
oOptions.Value("IncludeTitle") = True
'choose to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = True
' export the Partslist to Excel with options
oPartslist.Export(path_and_name & ".xls", _
PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
Can you change this line
to
oPartslist = oSheet.PartsLists(2)
Or try this
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 22145 StartFragment: 314 EndFragment: 22113 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'-------------Start of ilogic ------------------------------------------------
Imports System.IO
'Check to see if file is a drawing, exit if not
Dim oDoc As DrawingDocument
    'oDoc = ThisApplication.ActiveDocument
    If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
      Return
    End If
' Parts List Export Settings
oName = ThisDoc.FileName(False) 'without extension
'define oDoc
oSheet = oDoc.Sheets ("Sheet:1") ' sheet by name
'Check If a Parts List Exists
Try
Dim oPartslist As PartsList
'set as the first parts list found on sheet 1
'get Excel target folder path
oFolder = Left(oPath, InStrRev(oPath, "ENTER PATH TO TEMPLATE HERE")) & "ENTER PATH TO TEMPLATE HERE"
'check For existing XLS file And delete it If found
If Dir(oFolder & "\" & oName & "*" & ".xls") <> "" Then
Kill (oFolder & "\" & oName & "*" & ".xls")
Else
End If
'specify an existing template file to use For formatting colors, fonts, etc
oOptions.Value("Template") = "OENTER PATH TO TEMPLATE HERE\PartListExport.xls"
oOptions.Value("ExportedColumns") = "ITEM;QTY;DESCRIPTION;PART NUMBER / MATERIAL"
oOptions.Value("StartingCell") = "A4"
'specify the XLS tab name, I used the filename of the drawing
oOptions.Value("TableName") = ThisDoc.FileName(False)& " Rev " & iProperties.Value("Project", "Revision Number") 'without extension
'include the parts list title row
'autofit the column width in the xls file
' export the Partslist to Excel with above options
oPartslist.Export(oFolder & "\" & oName & " Rev " & iProperties.Value("Project", "Revision Number") & ".xls", _
'Exit If No Parts List Exists
Catch
End Try
'-------------End of ilogic ------------------------------------------------
@Anonymous
Thanks for the code.  I'm trying to get it to suit my application.  Unfortunately the Kill command deleted my template Excel file as well as the others that were in the folder. So while I wait for our IT guy to restore the backup I'll try and figure out why the code deleted all Excel files instead of just those matching the name of the drawing.
Update:
With help from
 I have a code which exports the material list using the template.  The only issue is it is exporting to my drawing file path which is on my workstation as I'm using Vault.  I need it to go to the server so my colleagues can access it.
Can anyone help with writing code that will export the file to a specified filepath?  The code above won't work for me.
Another update:
I've managed to get the code to work by extracting parts from the above code.  Reinstating the "Kill" command is proving difficult though, and I need to make sure it doesn't delete all the files in the folder like it did before...
The code I have so far is:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 15501 StartFragment: 314 EndFragment: 15469 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'define oDoc
oFolder = Left(oPath, InStrRev(oPath, "ENTER DESTINATION FILE PATH HERE")) & "ENTER DESTINATION FILE PATH HERE"
oOptions.Value("Template") = "ENTER TEMPLATE FILE PATH HERE\Template.xlsx"
oOptions.Value("ExportedColumns") = "REV;QTY;WIDTH;LENGTH;THK;ITEM;DESCRIPTION;PART NUMBER;MATERIAL;MASS"
oOptions.Value("IncludeTitle") = False
oOptions.Value("AutoFitColumnWidth") = False
hi jazz
to save to a folder use;
oFolder = Left(oPath, InStrRev(oPath, "O:\\whatever you want\goes here")) & ""O:\\whatever you want\goes here"
re: the kill command,
not sure what is happening with this at your end,  I'll look into it further though.
If you don't need this functionality you could just comment it out... when running the rule you should be prompted that the file exists and to click ok to overwrite the file?
When it gives the prompt and I tell it to overwrite, the resulting parts list is strange.  It's like it has taken some of the template but not all of it.  So for example the company logo is there but some of the formatting is wrong and information layout is strange...
I'll try again in case it was a glitch.
how can I get this to do partlist 2? or an specific partlist style only for that export? I have one that's called PartListExport BOM style that I would like it to call up.  Thanks!
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 836 StartFragment: 314 EndFragment: 804 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
doesn't work.
GosponZ
