- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I have multi-body part files and I'd like to export each solid body into separate STL files via the API.
The workflow I have currently is to make components and create individual IPTs for each body, followed by running the following script to export them to STL.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
For Each oOccurrence As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
Dim oCompDoc As PartDocument = oOccurrence.Definition.Document
Dim stlName As String= System.IO.Path.GetFileNameWithoutExtension(oCompDoc.FullFileName)+".stl"
Dim savePath As String = System.IO.Path.GetDirectoryName(oCompDoc.FullFileName)
Logger.Trace(savePath & "\" & stlName)
oCompDoc.SaveAs(savePath & "\" & stlName,True)
Next
MessageBox.Show("Done","ExportAllPartsAsSTL")
I'm wondering if there is a way to export the solid bodies directly via the API without having to go through the Make Component step?
Or if there is a way to access the 3D Print Environment via the API? Because in this environment, user can suppress individual bodies and export the remaining bodies as STL.
Regards
Ilyas
