Export DXF to specific location
cedric.pollet
cedric.pollet
Hello, I have written some code to export a IDW sheet to a DXF to a specific location on our company network. Only problem is that not all users have rights to modify or delete the file (only the admin and the user who did the export have full rights)
You can see my iLogic rule here:
Imports System
Imports System.IO
Imports System.Security.AccessControl
'********************************************Zet DXF instellingen******************************************
Dim DXFAddin As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
'Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\temp\dxfout.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'********************************************Creƫer path******************************************
	'Dim sMaterial As String = ThisDoc.Document.ComponentDefinition.Material.Name
	'Dim sThickness As String = Parameter("Thickness")
	Dim sStockNr As String = iProperties.Value("Project", "Stock Number")
	Dim sStockNrLinks As String
	'trace.Writeline("Thickness: " & sThickness)
	If sStockNr = "" Then
		'vbLf = carriage return
		sStockNr= InputBox("Stocknummer niet ingevuld !" & vbLf & "Geef stocknummer in:", "Onvolledig" , "")
	End If
	'Controleer of stocknummer 5 tekens bevat
	If Len(sStockNr) <> 5 Then
		i = MessageBox.Show("Ongeldig stocknummer ingegeven !", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		Return
	End If
	sStockNrLinks = Left(sStockNr,2)+"000"	'Voorlopig niet boven 100.000
	trace.Writeline(sStockNr.ToString() & Chr(13) & sStockNrLinks.ToString() )
	Dim sPATH As String
	sPATH = "L:\ASCI\PRODUCTEN\" & sStockNrLinks & "\" & sStockNr
	Dim sFilePath As String
	sFilePath = sPATH & "\" & sStockNr & "_" & ThisDoc.FileName(False) & ".dxf"
	'Dim UserAccount As String = "BASCULESROBBE\Users"
	Dim UserAccount As String = "Everyone"
	Dim FileInfo As IO.FileInfo = New IO.FileInfo(sFilePath)
	Dim FileAcl As New FileSecurity
	trace.Writeline("FileACL aangemaakt")
	'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.ContainerInherit Or InheritanceFlags.ObjectInherit, PropagationFlags.None, AccessControlType.Allow))
	'FolderAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, InheritanceFlags.None, PropagationFlags.None, AccessControlType.Allow))
	FileAcl.AddAccessRule(New FileSystemAccessRule(UserAccount, FileSystemRights.Modify, AccessControlType.Deny))
	trace.Writeline("Add accessrule ok")
	FileInfo.SetAccessControl(FileAcl)
	trace.Writeline("SetAccessControl ok")
	'Kijk of path bestaat en creer indien het niet bestaat
	If Not System.IO.Directory.Exists(sPATH) Then
		System.IO.Directory.CreateDirectory(sPATH)
	End If
'Set the destination file name
'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & sheetname & ".dxf" 'same folder, or uncomment:
oDataMedium.FileName= sFilePath
'oDataMedium.FileName = "L:\ASCI\PRODUCTEN\14000\14001\14001_0150001.dxf\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
i = MessageBox.Show("Preview the DXF file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
The code executes till the FileAcl.AddAccessRule
I get the following error:
Error in rule: Rule4, in document: 0150092.idw
Some or all identity references could not be translated.
System.Security.Principal.IdentityNotMappedException: Some or all identity references could not be translated.
   at System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess)
   at System.Security.Principal.NTAccount.Translate(Type targetType)
   at System.Security.AccessControl.CommonObjectSecurity.ModifyAccess(AccessControlModification modification, AccessRule rule, Boolean& modified)
   at System.Security.AccessControl.CommonObjectSecurity.AddAccessRule(AccessRule rule)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Anyone got an idea what the problem might be ?
Thanks in advance,
Greetings
Cedric
GosponZ
Thry this one
oPath = ThisDoc.Path
        oFileName = ThisDoc.FileName(False) 'without extension
        oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
        'Define the drawing
        Dim oDrawing As DrawingDocument
        oDrawing = ThisDoc.Document
        Dim oSheet As Sheet
        Dim lPos As Long
        Dim rPos As Long
        Dim sLen As Long
        Dim sSheetName As String
        Dim sSheetNumber As Integer
        'step through each drawing sheet
Dim Response As MsgboxResult
        For Each oSheet In oDrawing.Sheets
            Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
           If Response = MsgBoxResult.Yes Then
                'find the seperator in the sheet name:number
                lPos = InStr(oSheet.Name, ":")
                'find the number of characters in the sheet name
                sLen = Len(oSheet.Name)
                'find the sheet name
                sSheetName = Left(oSheet.Name, lPos - 1)
              'find the sheet numbe
            sSheetNumber = Right(oSheet.Name, sLen - lPos)
End If
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
      'get DXF target folder path
                oFolder = "c:\INVENTOR DXF FILES"
                'Set the DXF target file name
                oDataMedium.FileName = oFolder & "\" & sSheetName & sSheetNumber & ".dxf"
                MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
                'Publish document
                oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
            End If
        Next
